Differences between telecaster and Stratocaster pickups
  • Differences between telecaster and Stratocaster pickups
    Hi i just asking about the diferences in sound between this type of pickups, in this case the bidge, because i was reading in this forum (pickupedia)about the winding of this pickups and i`v found that they may not have a lot of diferences in this, but, why Possum build stat pickups with more winding than the originals, saying that the strat pickups are more difficult break up the amp? why the strat pickups have in general less gain than the telecaster pickups?
    Regards
    Juan Motta
    A tele bridge pickup has a wider spacing than a strat & a taller bobbin ,generally more wire than a strat p/up & lots of room to handle more wire
    plus the ferrous plate on the bottom & it being mounted into the bridge
    The traditional strat pickup is pretty limited ,unless you change it dimension's & design a little
      Seymour Duncan Faq #24 Has some good Info about the diff between Tele and Strat Bridge Pickups.
      1-25 - Seymour Duncan
      B_T
        Great help for this cuestion, anyone have a specific dimension of the flatwork and other info for building it? a jpg or pdf spec?
          In the stewmac.com i have found some spec for the alnico 5 rods, what do you think about? the dimension are right?
          STEWMAC.COM : Single-coil Alnico 5 Magnet
          i
            i
            Here's all the parts for a Tele bridge pickup:
            STEWMAC.COM : Parts Kit for Tele Bridge Pickup
