Page 1 of 2 12 LastLast
Results 1 to 35 of 47
Thread: multi-gauge wire humbucker question
    Supporting Member belwar's Avatar
    Jul 2008
    1,066
    I'm trying to remember the answer to this question, but for the life of me I cant remember it...
    If you were making a basic side-by-side coil humbucker with two different gauge wires (i.e. slug 43awg, and screw 42awg) what gives you the maximum hum cancelling? Is it equal number of turns on each coil or equal DC Res?
    I remember dimarzio used to have a patent on multigauge pickups, but i think its expired now. Did anyone ever get a nasty letter from them about it?
    bel
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Equal turns will get you very close but it's really turns * area and the area of a 43 coil might average ever so slightly smaller than a 42 coil.
    Jul 2008
    1,066
    this may sound stupid, but can you define "area"? Do you mean the total volume taken up by the wire? Total surface area on the wire? How would I even begin to calculate something like that?
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Mmm, I would define it as the area that fits inside the coil from what I understand. So presumably you would measure the area of the middle-most layer of wire in the coil. If your coil "A" starts being 1/4" x 2" and finishes at 1/2" x 2.25" your average coil size would be 3/8" x 2.125". The "A" coil area would be 0.797" multiply that by 5000 turns to get coil x turns of 3985.
    If you know that your coil "B" is 43 awg and is say 5% smaller than coil "A" you might want to add 5% more turns to coil "B" or 5500 turns.
    Jul 2008
    1,066
    Hmm interesting. Seems totally unscientific. Ill try it. Hey so you remember the name of that crazy expensive solder we were talking about recently? I will cant find the discussion for the life of me
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,315
    Received: 206/21
    Given: 215/9
    I was of the understanding that equal amount of turns of each would give best Hum Canceling.
    I make one all the time, full screw coil with 42 SPN, and fairly full slug coil of 43 SPN.
    It hums a little but not bad. I'm sure it would be quiter if both coils were equal.
    Makes a good hot pickup.
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Quote Originally Posted by belwar View Post
    The wonder solder? It should pop up in a search, I scabbed it onto some totally unrelated discussion. God knows what but search anyway.
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,083
    Received: 19/0
    Given: 13/0
    Supporting Member
    Sep 2007
    3,034
    Received: 23/0
    The law of induction works on the time varying magnetic flux for any closed path. That is, what matters in effect is the time varying flux through each turn, with all of them added up. So, if all the turns had the same amount of flux passing through them, it would just be the total number of turns that counts. And that's not such a bad approximation for a pickup with cores because the cores concentrate the flux more to the middle of the coil, and the varying size of the turns is less important than it might be.
    (If the flux is constant throughout the loops, the area of each loop times the number of loops is very accurate. This is a very goo approximation in some cases)
    (To be very accurate, you integrate the spatial varying time varying flux over each loop and add the results. We do not have accurate enough measurements or predictions to do it exactly.)
    Mar 2010
    481
    Given: 2/0
    So, do we think that the quietest practical (although not particularly appealing) setup in a situation with two different wire gauges (same # of turns) would be to use the same core material in both coils and then add a small resistor to the heavier gauge coil to match resistance?
    Well... after running out of the house immediately after posting this it occurred to me that this kindof kluge would only apply to the parallel configuration, so... in the immortal words of Gilda Radnor - "Never Mind!"
    Bob Palmieri
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    I do equal number of turns. You can also alter that for different tones.
  12. #12
    Old Timer
    Oct 2011
    1,951
    number of turns govern the inductance, not the gauge of the wire. You need to match the number of turns as long as the two bobbin is exactly the same. If the cross-sectional area in the middle of the coils are different, then all bets are off. Good example is the Suhr noise cancelling coil. It has much less turns but with a big loop, it can cancel noise with much fewer turns because the center area is much bigger and can sense much more magnetic flux.
  13. #13
    Jul 2008
    1,066
    Ok now that makes sense! Thanks. Your suhr reference was perfect.
  14. #14
    Old Timer
    Boston, MA area
    2,616
    Received: 3/0
    Quote Originally Posted by big_teee View Post
    It is not the number of turns, it's the area-turns count. That is the basic rule, absent any nearby iron. The "area" is that bounded by the turn in question. In practice, we use the average area of turns, and multiply by the turns count, and it's close enough.
    Note that the inductance is not the issue, it's the area-turns product, which controls the voltage generated by a coil immersed is a uniform changing magnetic field. The difference is that the inductance varies as the square of the turns count, while the area-turns count varies linearly with the turns count.
  15. #15
    Jun 2010
    Mid-South USA
    10,315
    Received: 206/21
    Given: 215/9
    Quote Originally Posted by Joe Gwinn View Post
    If you had 5000 turns 42 and 5000 turns 43 is that equal in Hum reduction?
    I usually do highly mismatched coils and hope for the best.
    T
    Keep Rockin! B_T
  16. #16
    Jul 2008
    1,066
    Joe - Do you have any good resources to learn more about area-turns product? Are you aware of any matematical way to calculate this measurement? I would be great to be able to have a formula to calculate "approximate" required measurements for hum cancellation when dealing with multigauge.
  17. #17
    Jun 2010
    Mid-South USA
    10,315
    Received: 206/21
    Given: 215/9
    But don't you find anything in the general ball Park to be pretty much Hum canceling?
    I Make what I call a Hybrid. I wind the screw bobbin Fairly full with 42SPN, and about all I can get of 43 SPN on the Slug Coil.
    Not sure on the turn count, but pretty sure highly mismatched in favor of the 43GA.
    It is nearly as quite as my 7.2k Symmetrical Wound Neck Pickup?
    What is your Experience?
    Keep Rockin! B_T
  18. #18
    Jul 2008
    1,066
    sure I could just start winding and try, but i'd like to try to get an understanding of why/how it is functioning. I'm having a difficult time understanding the "coil area".. Trying to remember back to my high school math class, I thought that area was a two dimensional measurement - So in a three dimensional coil, what area is it measuring?
    The area around the core? i.e. a top down view?
    one side of a side view?
    Front view? (clearly unlikely)
    I'm dumb as a cork, but I want to learn
  19. #19
    Senior Member frankfalbo's Avatar
    Jan 2008
    California
    214
    Hopefully someone chimes in with a mathematical answer that satisfies you. In the mean time I find the rudimentary way to consider it is simply as an audio condition rather than a mathematical one. You have two signals summing. They don't phase cancel the audio, just the hum. So for hum cancellation perfection all you need is for each coil's noise to be as loud as the other's. Turn count is only one way to affect that. Creative shielding and purposeful ground or float decisions for each component can fine tune the noise level as well.
  20. #20
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Bel,
    I'll try to reply with a little more clarity. You are correct, you want to measure the top-down, 2 dimensional window through the coils, and yes, area is the width times the length of the bobbin core. As each layer of wire piles up on the bobbin, it takes in a slightly larger area. You can figure out the average area of each coil by measuring the area window through the layer that sits exactly half way through the wind. If you wax potted the 2 coils and sliced each off the bobbin and then peeled each apart right at the middle layer, you could lay those outer layers side by side (but reassembled and maintaining their former, oblong shape) and hopefully see that the 43 awg coil is the same percentage smaller in window area as the difference in wire diameter times π i.e. the wire cross section. (2πr is the area of a circle, the wire is round). To mathematically find the area you can break the coil shape into 3 parts, a half circle at one end, a rectangle in the middle and an identical 1/2 circle at the other end. Now we can presumably ignore the rectangles because they're going to be the same length on both coils and their widths are the same as the diameter of the two half circles from each coil. If I were really good at geometry I could pull the theorem out of my butt and prove to you that the difference in wire diameter is going to be the same as the difference in coil area between your 42 and 43 wire cross-sections. I absolutely stink at geometry and have no idea if that's actually true, right now it's a strong hunch.
    I looked up on a table that AWG 43 = .0025 mm^2 and AWG 42=.0029 mm squared . I divide 29/25 = 1.16 or that for every 100 turns of 42AWG you might need 116 turns of the 43 to get to the same size coil. I don't think we need that many extra turns to equalize turns areas, I'm guessing we need about 1/2 as many or 108 turns but I can't tell you why.
    Someone with better 8th grade math needs to come in and save me here.
  21. #21
    Mar 2010
    481
    Given: 2/0
    So, I put one of my very-well-matched two-coils-on-the-same-axis pickups on my main axe and it seemed to hum a lot more than I would expect.
    So, I figured maybe it wasn't as well matched as I thought and put in another one. Same deal, and the neck pickup was still dead quiet (it,in fact, is using two different gauges of wire on the coils.)
    So, while I was scratching my head about this my eyes went over to this big honkin' piece of metal a half-inch away from the pickup (namely the integrated bridge/tailpiece on my Melody Maker) and I began to wonder if its proximity to one coil could explain this phenomenon. I haven't yet done any of the obvious tests yet, and I need to leave for a trip early this morning.
    So, before I do test for this, whaddya think?
    Bob Palmieri
  22. #22
    Junior Member
    May 2010
    Michigan
    20
    I just wound some stewmac humbuckers both around 9k... screw bobbin with 42 awg 5000 winds and slug bobbin slightly overwound 5400 or so winds with 43 awg and covered with gold cover and AllStar Magnetic Alnico II. Made the mistake of not wax potting again after I put the covers on, so bridge was pretty feedbacky, and I had to take he cover off. I think the bridge was a little too thin and strident... need to come up with a warmer recipe, but a fine experiment!
  23. #23
    Jun 2010
    Mid-South USA
    10,315
    Received: 206/21
    Given: 215/9
    Quote Originally Posted by NPB_EST.1979 View Post
    Try a full Screw coil of 42 & a full slug coil of 43, with a A2 as strong as you can get it.
    It sounds great, I have one in my LP Copy.
    I have that in the bridge, and a Symmetrical A2 in the neck, IMO they sound great together.
    B_T
    Keep Rockin! B_T
  24. #24
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Quote Originally Posted by fieldwrangler View Post
    Do you have the coils wired in phase?
  25. #25
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Yes, it will hum cancel.
    What are you trying to achieve with the mismatched coils? More treble?
  26. #26
    Mar 2010
    481
    Given: 2/0
    Definitely.
    I'm planning to check out the hairbrained idea that maybe proximity to the bridge is unbalancing the thing this weekend.
  27. #27
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Definitely.
    Definitely in-phase? Humbuckers are wired out-of-phase. That might be why its humming. Either that, or it doesn't know the words.
    Wire them start to start, or finish to finish, wound the same direction.
    Many of my bridge pickups use multi gage wire. That's not the issue.
  28. #28
    Jun 2010
    Mid-South USA
    10,315
    Received: 206/21
    Given: 215/9
    OverWound Bridge P/Us do seem to pickup more noise and are more sensitive, and have more gain, than a low wound neck P/Us.
    Some Amps are way more noisey than others.
    IME Head Amps are usually quieter than Combos.
    B_T
    Keep Rockin! B_T
  29. #29
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Maybe because they are overwound? (i.e. louder?)
    I'm not sure we are talking about overwound pickups here. Either way, even over wound humbuckers should be quiet.
  30. #30
    Mar 2010
    481
    Given: 2/0
    Quote Originally Posted by David Schwab View Post
    Well... in this case they're sidewinders. I've been winding these for 20 years (perhaps almost as long as you!) and I actually connect them in electrically in-phase series (head to tail) but point them in opposite directions. Not that there's not a big chance of me screwing up, but if I had done so I'd notice a quite unexpected timbral quality before the hum thing became apparent.
    And in fact, my neck pickup (also a sidewinder) is also a multi-guage unit and is nearly dead quiet.
    By the way, this "sidewinder" term is something I learned from you, and is much more convenient than my previous "horizontally opposed coaxial" monicker.
    Bob Palmieri
  31. #31
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    So no one is willing to come out with a workable mathematical formula for hitting the hum-canceling nail on the head with two different gauge wires?
  32. #32
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Quote Originally Posted by David King View Post
    I thought it was already stated; you wind the same number of turns for each gauge. That's all you have to do.
  33. #33
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Oh I didn't realize you were talking about sidewinders. I notice if the sidewinders are wired up wrong they hum but don't sound all that much different. I also find i have to make sure the poles are grounded and I shield the entire pickup, otherwise they seem susceptible to buzzing.
    I set my coils up with both tops facing the poles. Because of that the windings are in opposite directions, then I wire them in phase. The same magnetic polarity is facing the poles.
    I didn't make it up!
  34. #34
    Mar 2010
    481
    Given: 2/0
    Yes; and this sort of thing sometimes scares me. Makes me feel that there's something fundamentally funny about this design, sorta like early stacked Strat pickups with limited magnetic isolation between the coils. I do however, continue to bark up this tree with a vengeance.
    I'm pretty obsessive about those grounding/shielding issues.
  35. #35
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    David,
    Where did you get that from? That would be great news if it's true, I just want to make sure we can put this to bed before we get totally sidewound on other topics...
  1. Speaker wire gauge question
    By txstrat in forum Theory & Design
    Last Post: 06-24-2011, 07:54 PM
  2. Wire gauge
    By SpareRibs in forum Beginner/ Hobbyist
    Last Post: 03-19-2011, 07:01 AM
  3. How to measure wire gauge?
    By belwar in forum Pickup Makers
    Last Post: 10-27-2008, 02:50 PM
  4. What gauge speaker wire?
    By benindavis in forum Theory & Design
    Last Post: 09-03-2008, 08:37 AM
  5. Noob Humbucker Start Lead Wire Question
    By PoorMan in forum Pickup Makers
    Last Post: 05-10-2007, 07:42 AM
