Anyone have a George Stevens coil winder in here?
  • Anyone have a George Stevens coil winder in here?
    Hello all,
    I have a 1950's George Stevens model 250? cam drive winder here I'm trying to restore. Unfortunately, I got it in a million pieces.
    Would any of you who do use this winder have a good photo of the inside of their gear and cam case, so I can reassemble mine?
    Thank you,
    ken
    www.angeltone.com
    Ken I posted photos of a Geo here a year or two ago, those might be helpful or might not as I never knew what model I had but I think the 250 was close enough.
      Ken,
      I use a Model 225 AMVP and have a lot of documentation for it. I'm not sure how it compares to your Model 250. Do you have any photos?
      sigpic
        Ken,
        I have an early 50s Geo Stevens winder that I will be glad take some pictures of the cam mechanism and idler gears for you. Let me know if you need pics of other portions of the winder as well. Give me a few days to do this --- very busy this weekend. I know it’s not a model 250, but it still might help.
        Terry,
        I’d be curious to know if any portion of your documentation covers gear ratios, TPL, and the like. I have no documentation for this particular winder. Please PM me if I can get a copy of yours.
        Keep winding!!!
        Jim
        Keep Winding...Keep Playing!!!
        Jim
          Geo Stevens Winders
          Jim,
          PM sent.
          sigpic
            I was mistaken - my winder is a model 120M. I think mine is from around 1954.
            David, your winder is somewhat like mine, but I have a chain driven electric counter and braking system instead of the clock style counter you have.
            As far as I can tell I need to find a cam and followers, change gears, and the front cover. I was thinking about making a clear lexan front cover so I can watch the gears go around.
            I have a photo of it when I just got it, I'll see if I can find it.
            ken
            www.angeltone.com
              Here is a catalog picture of my Model 225. This is a later version of the one in David's photo. It is a cam-and-gear machine that can handle most electronic coil styles, including PUs. There are two change-gear cover plates (one front & one rear).
              Also, I have included the assembly drawing and parts list. I hope you find this useful.
Name:	Catalog Picture Model 225-AMVP.jpg
ID:	823304Click image for larger version
Name:	Assembly & Parts List Model 225 AMVP_Page_1.jpg
ID:	823308Click image for larger version
Name:	Assembly & Parts List Model 225 AMVP_Page_2.jpg
ID:	823309Click image for larger version
Name:	Assembly & Parts List Model 225 AMVP_Page_3.jpg
ID:	823310Click image for larger version
Name:	Assembly & Parts List Model 225 AMVP_Page_4.jpg
ID:	823311Click image for larger version
Name:	Assembly & Parts List Model 225 AMVP_Page_5.jpg
              sigpic
                Thank you for the photos.
                TubeType's photo has my electric counter and control box, but I have different tensioners designed for very fine wire. I don't have the big round manual traverse? knob assembly at the bottom of my gear case either.
                Does anyone know if Geo. Stevens still sells cams and change gears for their early winders? I want to set up my winder to only wind humbucker coils.
                Ken
                www.angeltone.com
                  Ken,
                  Here are some closeups of my Geo Stevens winder. Hopefully, along with the documentation that Tube Type posted, these will help you get your machine together.
                  Keep us posted on your progress.
                  Keep Winding!!!
                  Jim
                  Jim
                    Thank you all for your help.
                    I think I have enough info from the photos you all sent me to get the gearing together.
                    Now all I have to do is go 'gear hunting'...
                    ken
                    www.angeltone.com
                      Ken
                      Hello Ken,
                      I'm glad to help. The contact information for the George Stevens Company is:
                      George Stevens Mfg.
                      Peter Urbanski
                      Division Manager
                      Phone(630)406-9550
                      www.geostevens.com
                      Peter was very helpful, but spare parts for the vintage machines are made to order. You can expect to Pay, Pay, Pay. I recently spent $800 for a cam shaft and its brass bushing. The gears start at around $80 for the smallest and go up from there.
                      sigpic
                        It might be worth looking over the offerings from Boston gear to see if they can be modified to work. If Mr Urbanski can tell you what the gear pitch is you might be able to take it from there.
                          I did some research today...
                          Most Stevens winders use 48 pitch gears 1/8" thick with 1/4" ID shaft holes.
                          I'm told many larger RC trucks use the same pitch gears in nylon or aluminum alloy for their gearboxes.
                          Therefore, new gears should be as easy to find as your local hobbyshop.
                          You may have to open up a center hole or two, but it's way better than nothing.
                          I'm looking for two things right now - the 'left hand' (spring loaded) cam follower, and the schematic diagram for the original power supply/brake control box. The sucky thing is I **KNOW** I have a copy of the diagram somewhere here too, I just can't find it. Looks like I'll be calling Geo. Stevens and see what parts they still have left. Thank you TubeType for the contact info.
                          Thank you all for helping me... I have a .pdf copy of Querfurth's book on Geo. Stevens winders (the original manual sold with the winders from the 1950's) for any of you who PM's me and asks for one.
                          Thank you,
                          ken
                          www.angeltone.com
                            Geo Stevens Speed-Brake Control
                            Ken,
                            I have the schematic for the speed/brake control box. I'll scan and post it here later today.
                            Here it is. Enjoy!
Name:	Speed-Brake Control.jpg
                            sigpic
                              Thank you for the schematic! I have the original motor and gearbox for my winder but I wanted to convert it to use a modern 12VDC motor. It looks to me like this outputs about 110VDC max to power the brake as well as the motor, so I'll have to get a transformer and rectifier to use my new motor. Instead of the 150 watt rheostat, a Harbor Freight router motor speed control should
                              work well too.
                              ken
                              www.angeltone.com
