Peavey CS800 series ?
  • Peavey CS800 series ?
    Hi folks,
    quick question Would this CS800 be a series A ?
    CS800 C series has two ICs on each volume control board, and two ICs on the driver card. Two rocker switches on front, powr and fan speed. Volume control has pull switch.
    CS800 B series has almost nothing on the volume control board, just two small transistors - and even they only have two leads connected on each. Only one IC on the driver. Same two rocker switches on front. No pull switch on volume.
    CS800 A series. AS I recall these are mostly just like teh B, but some of them had only a push switch for power and a temoperature light for the fan speed. It looked like the push switch, but the light was justa light.
    Yours is probably a C.
      Thanks Enzo. What I have on the front is one rocker switch for power ,and a white light that looks like a push button for high temperature ?
        Blue l.ight?
        SOunds like a A series.
          Originally posted by Enzo View Post
          Blue l.ight?
          Light may be blue, plastic looks white. Thanks Enzo
            White switch works for me.
