More component help!
  • More component help!
    Ive done a fine job of building 2 GGG pedals that wont work! hehe..
    Rodent RAT clone- couldn't find a LM 308; saw on Wikipedia LM 741 'often used instead': so with this in and all else as per http://www.generalguitargadgets.com/..._rodent_lo.pdf only get very low level rat noises (sounds Ratty tho- good!), Filter pot no effect at all, and Drive pot shuts off all vol on full clockwise rotation, as does Level pot-?
    Anderton Tremolo- got ICs in.. ahem.. right way up now, ordered a nsl-32 (has nsl 7053/ SR2/ 15B on.. no '32' at all-?) for a CLM6000. No sound at when switched on.. switched off, amp is heard as per normal.
    Wondered if either my subsitute parts need other stuff of differing values/ or even differing circuit parts? also pots: I presume 321 is wiring looking at pot back? I have actually built these with care, checking wiring etc.
    Any help would be great, thanks. Capt
    Anyone built either a Rodent or a Anderton Tremolo/ are the build pages right? Ive tried TL071 in the Rodent, checked all wiring & layouts but still neither work..
      The 308's can be had from Steve at Small Bear Electronics..
      website at http://www.smallbearelec.com/home.html
