I would make a guitar but I don't have a big enough bench! Here is a violin I made a few years ago and one I am working on. I have had very little time to make violins lately, kind of a bummer. I learned from my grandfather and some other great makers. Like most fanatical violin makers I don't use any sandpaper on the white wood. Only razor sharp gouges, files and scrapers do the finish work. On the varnish and fingerboard, sure sandpaper and micromesh when needed, but don't tell anyone!
Ever make your own guitar?
Originally posted by jason lollar View Posti even cut the tree down the maple came..
You know what really disturbed me lately, was seeing these old large maple trees come down during the hurricane, and then they get chopped into small pieces and run though a wood chipper! It makes me sick to see that. What a waste of some beautiful old growth wood.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by StarryNight View PostI'm always curious about luthier's choices of finish. I know the choice depends on many factors but I wonder what builders prefer and what they consider a compromise?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
So much of what luthiers do these days in influenced by the market. If it's a classical guitar it *has* to be French polish. If it's a retro electric it obviously *has* to be nitrocellulose.
Meanwhile the finish industry is being revolutionized but environmental concerns and legislation. Unfortunately for all of us guitar players will be the last to find out where the state of the art has moved to.
I'm using a newish finish from Canada that's as hard as polyester, has 0 shrinkage and nearly 0 VOCs. It's brush-able and cures in under an hour in sunlight. Suddenly I can compete with factory UV finishes at home without even a spraybooth. That's pretty incredible after wasting years on Bull-S waterbased finishes, spending thousands on spraybooth, supplied air breathing apparatus, HVLP sprayers, compressor and UV curing light.
Originally posted by David King View PostSo much of what luthiers do these days in influenced by the market. If it's a classical guitar it *has* to be French polish. If it's a retro electric it obviously *has* to be nitrocellulose.
Problems I've always had with water based finishes is first, the look. They just don't have that warm look of either nitro or shellac. Second - the feel. Water based and polyurethanes feel more "plasticky" to my hand. Nitro is more familiar. A lot of my clients are the same and insist on nitro. I would love to have an alternative with the qualities mentioned above that is enviro-friendly. Until such time, I'm using nitro.
Cheers,
Hi Peter, the stuff in question is called Duo.V FS. -not much of a name. You might want to wait until summer to experiment with it unless you already own UV curing equipment.
StarryNight, Tung oil is a mess, it picks up dirt like nobody's business and take years to cure. A lot of that's called "Tung oil" is actually something else entirely.
Originally posted by StarryNight View PostDoes tung oil appeal to anyone? I've seen pics of some surprisingly high gloss buffing with tung oil.
David K you're not referring to Canadian maple syrup? That stuff is good on just about anything!
And it may be that Canadian maple syrup is good on many things. But I've found it disappointing on pancakes."Take two placebos, works twice as well." Enzo
Originally posted by David King View PostA lot of that's called "Tung oil" is actually something else entirely.
Lee Valley Tools - Finishing with Tung Oil
That article is excellent information from a finishing standpoint. Though there are some implications that are suspect. One that stands out for me is that at the end they tell us how to handle our tung oil. Lumping all the discussed incarnations together. This isn't entirely accurate since they are very different finishes. As different as boiled linseed oil and polyurethane. Incidentally... A good way to be sure you have an air tight seal is to store your containers upside down. Something no one would do with a leaky container (eliminating laziness...guilty) and if there is a pinhole leak it will resolve itself in short order. If a little spilled finish on your finish storage shelves is a problem then you may just want to buy new stuff for every project and evaporate the leftovers."Take two placebos, works twice as well." Enzo
Thanks for the info David, I will look if up.
A trick for getting warmer appearance when using water based finished is to start with a few coats of Shellac and then switching to the water based lacquer for building up the finish. That will really bring out the natural look of the wood.
