The bridge pickup on my bass appears to be shorting out, unless there is an issue with the Balance pot or Circuit for the bass.
balance volume pot: set to neck bass works fine
balance volume pot: set to bridge, doesn't work properly. You get extremely intermittent signal. Mainly when you play the bass VERY VERY HARD.
volume, treble, mid, bass pots are all working properly
-when i throw the ON/ON Mini Toggle SW to the DOWN position (looking from players view) the signal on the working pickup is fine
-when i throw the ON/ON Mini Toggle SW to the UP position (looking from players view) the signal on the working pickup is extremely loud
-switch has no affect on the intermittent Bridge pickup, although tied to it through the MK-1 Board.
I have a replacement pick from Bartollini, however I don't want to install it if in fact its the Balance Pot or the Switch...
How can i properly test them?
Thanks in advance for any help...
