Page 5 of 5 FirstFirst 12345
Results 141 to 145 of 145
Thread: 4 Tube Amp From Scratch
  1. #141
    Dec 2008
    Wernersville, PA
    13,004
    Received: 569/3
    Given: 298/0
    28
    Have fun with your new scope.
    Dual trace capabilities is a real nice feature.
  2. #142
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    9
    Thanks a lot, Mr. Bass!
    I am watching lots of vids and trying to go slow so i learn it and know it's limitations. One thing is the 250v peak max on the probes, so I'm a little nervous about using it on tube stuff, but I have much to learn.
    Very cool that with dual-trace you can check out phase issues.
    Sounds like you have one, any input for me on using it with tube gear?
    By the way, what bass amps have you made/bought? After this project (and my tube eq) i'm building my brother a B-15n, already have all the parts and the iron from Mercury (like $450 worth!!!!!). I've also seen a killer project that allows you to switch between 3 different B-15 models (like switching between SS and Tube rectification, etc).
    Hope you slept in, did what you wanted and ate like a fiend today! I sure did. :-)
    Re: the layout. I have to look into the heater wiring a bit more, this isn't right.
    Re: next holiday season. Going to find a way to take all my dead tubes and stick a bunch of LEDs in them and string them up as the ultimate tube-lover xmas lights!!! Anyone interested in a set?! I have like 200 TV tubes to spare!
  3. #143
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    9
    a wee update and a new question...
    I figured I'd just dive in on soldering it up and see where that lands me. I'm about 3/4 of the way done on it; probably only one more session to go and it should be ready for the smoke and poke testing.
    Hoping I find my variac in storage tomorrow. If not, i still have my lightbulb-test setup here on hand.
    (Will be double checking all the wiring before then)
    Question: Since it seems i can't get a presence control happening on this design, (and since i already drilled the hole for its pot; what a gun-jumper!), I'm wondering if i can make it a pre-amp output jack, instead. Since the signals rolling thru the 6AT6 and the 12AX7 it could be a fun pre-amp sound. Any input on that output anyone?! :-)
  4. #144
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,768
    Received: 2,610/4
    Given: 3,067/0
    30
    You might use a preamp out, and you might not. The real tone generator in this design is the power tube and speaker, it's such a simple amp. How about a power reduction switch? The switch could insert something like a 5R/5W series resistor and another 5R/5W parallel to the speaker making the amp about 1/3 power. Since even a small, single ended amp can be too loud at times for home practice when cranked it would probably get more use than a preamp out... You asked
  5. #145
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    9
    Hi Chuck!
    I think that's a grand idea.
    Though I am curious about the preamp, so if that's doable, i might give it a go. I'll take a look at some schemos and see if i can figure something out.
    So, for the power reduction, that's one resistor in series between the OT and the speaker jack, and another going across the two output jack leads?
    Also, couldn't I just do an extra jack on the back without a switch?
  1. Wanting to build a bass amp from scratch
    By Dennis in forum Build Your Amp
    Last Post: 01-15-2012, 07:32 AM
  2. Power amp design from scratch
    By newbambeeno in forum Theory & Design
    Last Post: 02-22-2010, 06:04 PM
  3. Tube amp addiction, tube amp dyslexia and ECT
    By tubeswell in forum Guitar Amps
    Last Post: 11-26-2009, 08:56 PM
  4. B&K Tube Tester & output tube question
    By Chevy in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-13-2008, 02:08 PM
  5. Want to build something from scratch
    By slaytalera in forum Build Your Amp
    Last Post: 01-10-2007, 07:27 PM
