behringer power supply?
  • behringer power supply?
    Hello, I have a Behringer Eurorack MXB1002 I'm fixing that someone gave me a while ago.
    I don't have the external power supply, does anybody know what the ac voltage in/pinout is?
    It also runs on batteries, so I'm using a dc power supply right now.
    I know they sell replacements for around $30, but I have a ton of supplies lying around I could probably use.
    Thanks.
    A three-pin mini-DIN connector?
    The mixer runs on +/-15 inside, and the incoming AC is half wave rectified before the Vregs. SImple as it gets.
    The adaptor for a similar Behringer mixer is rated 16VAC 1100ma.
      Thanks.
      Just remembered I have another Behringer mixer with external AC supply.
      I'll have to check the model and jack to see if it's compatible.
