Originally posted by big_teee
View Post
Crock Pot Surgery!
OK, so the Mini Crock pot is not usable for me, to pot pickups. It gets the wax so hot that it deformed an ABS bobbin so badly that I can't use it.
I'm going to have to go back to my leaky paraffin warmer unless I can knock the temperature down.
Oh well, at least it was cheap.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostOK, so the Mini Crock pot is not usable for me, to pot pickups. It gets the wax so hot that it deformed an ABS bobbin so badly that I can't use it.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Originally posted by big_teee View PostMake the 100Watt dim bulb tester, it takes about 30 minutes and a few bucks.
TIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by big_teee View PostHope the new place comes with a shop building?
T
So I will have more room a better winding setup at least.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by big_teee View PostHere's a Pic of my 2 bulb tester.The Blue Guitar
www.blueguitar.org
Some recordings:
How come no one has opened up the thermostat on the crock pot yet? It's probably a bi metal thingy. If so you could probably bend, test, repeat until it holds the wax at the correct temperature."Take two placebos, works twice as well." Enzo
Don't have time!
Too busy trying to get pickups made to put in the Crock Pot!
I thought about getting another one to work on, til I got it right.
Then I could work on the first one.
You may use one of those $2 bimetallic temp sensors usually attached to heatsinks.
Maybe you even needn't *buy* one, but cannibalize one from a dead amp.
You bolt it to the bottom or side of your crockpot , your choice, waterproof the screw holes with some silicone rubber and, of course, do not forget to insulate the 120V carrying terminals.
You may even wire a neon lamp across the thermal switch legs to show its operation.
They usually trip around 75ºC , do the math.Juan Manuel Fahey
Wouldn't a harbor freight router speed control ($9.99) keep a lid on a crock pot.
Someone needs to bite the bullet and hook up a PID controller PID controller - Wikipedia, the free encyclopedia (about $20) and take care of this problem in the most elegant way possible.
Originally posted by David King View PostWouldn't a harbor freight router speed control ($9.99) keep a lid on a crock pot.
I read about it, and am still Wondering, "What to Hell is It"???
My crock pot, only cost a couple bucks on sale.
Hate to have to hook a Nuclear Reactor to it to control it!
Weeellll, it might actually *be* hooked up to a Nuclear Power Reactor, for all I know.
Although maybe through a 2000 mile power line, of course.
Unfortunately, the only abbundant power source left, for now, is Nuclear.Juan Manuel Fahey
Dimmer control of crockpots
A crockpot with a hi-lo-off switch or a non-electronic bimetal controller can be controlled with an ordinary lamp dimmer. A large crockpot uses about 300 watts, half what the typical wall-mount lamp dimmer can handle.
If the crockpot has any electronics, no go. Unless you eviscerate it.
