I've seen a couple of schematics that had resistors on one plate in each pair in a quad power stage. (I think it was some Marshall amps.) What is the point? Is it to prevent some sort of oscillation..? Just curious, if anyone would chime a little wisdom here...
Uneven resistance on plate
Can you provide an example.
That makes no sense.
How can the current be shared , being in parallel, if there is a resistor on one tube of the pair?
FYI: I looked at every Marshall schematic that I have.
None have a resistor on the plates of the output tubes.
Excepting the 200 watt Major.
In that case all four KT88's had a 100 ohm resistor on the plates.
I don't see any resistors connected to the plates. Grid and screen resistors are the same for push & pull. Please specify the component numbers you mean.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I had this question with a Traynor YGL-3 Mark III. This amp also has a quad of power tubes.
Enzo provided the answer:
"Provides some isolation between the tubes.It prevents the screens from interacting"
http://www.webphix.com/schematic%20h...ii_ygl3_3a.pdf
Thanks Markr, now I see it, 2 screens with screen resistors, 2 screens straight to the screen supply.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
