Ok so I thought I would give winding a s.d. screaming demon a shot .did some google searches and most believe its wound with 43awg to 10.0kohms..so I found a screaming demon measured it and it has balanced coils of just a bit over 5.0....I wound one up and plugged it in and it is really weak.I have a jcm900 with the gain at 8 and it sound sounds like I'm on the clean channel.what gives I'm at a lose.
underwound 43awg pickup
Can you give us more details.
It looks like a Humbucker with A5 Magnets.
Looks like one bobbin has screws with a keeper bar and the other has allen set screws?
Is this correct?
Terry"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
I believe a screamin demon has one side fillister screws & one side allen head screws .
Using 2 screw bobbins ,The allen side screws are shorter & hardly stick through the baseplate
I have never had one apart ,but i am curious if it has 2 keepers"UP here in the Canada we shoot things we don't understand"
Yes one coil has screws and the other allen heads.alnico v magnet.43awg wound to 10.4 roughly. Balanced coils to the same number of turns.I even went and rewound the screw coil a second time thinking I did something wrong.it has no guts.its completely clean sounding with a gain heavy amp.
Originally posted by tpruitt View PostYes one coil has screws and the other allen heads.alnico v magnet.43awg wound to 10.4 roughly. Balanced coils to the same number of turns.I even went and rewound the screw coil a second time thinking I did something wrong.it has no guts.its completely clean sounding with a gain heavy amp.
feed the start of one coil, and tie the finish leads together and ground the start of Other coil.
Or, accomplish the same as above with a 4-Wire Cable.
Both coils wound in the same direction.
Make sure there is no space between the magnet and the allen screws.
There should be a keeper bar on the Fillister screw coil.
Make sure the magnet is properly charged.
Make sure the screws on both coils are steel and will stick well to a magnet.
It should work.
I apologize if I was too elementary, but don't know your level of winding.
Good Luck,
Originally posted by tpruitt View PostTriple checked all my wireing. And both coils have a spacer bar and the magnet is charges and against the keeper bars.it works its just really weak.I'm no expert. I am thinking maybe 43 gauge underwound to 10k just can't be done?
I make a hybrid that has one bobbin at 5k 42, and one bobbin 8k 43, and it is far from weak.
For the sake of the experiment, put more wire on the bobbins.
Try different magnets if you have them.
I make a 10k with 42SPN with Ceramics, and it is real hot also.
Did you check to make sure all your screws and keepers are magnetic, and no stainless steel?
Good Luck,
10k of 43 awg can be done just fine. You say it's weak, is it just quiet with a normal tone, or is it very heavy on the treble indicating it could be out of phase? Try wiring one (just one) of the coils backward, as big T mentioned.
Do you actually read 10k if you measure the resistance of the assembled pickup?
It sounds like to me you are just activating one coil.
If your only using one coil it would be weak.
If you are using a 4 wire cable for series wiring, try reading start to start and That you have the 10k DCR Total.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Originally posted by tpruitt View PostOk so I thought I would give winding a s.d. screaming demon a shot .did some google searches and most believe its wound with 43awg to 10.0kohms..so I found a screaming demon measured it and it has balanced coils of just a bit over 5.0....I wound one up and plugged it in and it is really weak.I have a jcm900 with the gain at 8 and it sound sounds like I'm on the clean channel.what gives I'm at a lose.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Not sure how I did it but it was out of phase.I must have gotten my wire colors wrong coming from the coil wires.thanks for everyone help on this one.I triple checked and everything looked right.anyways this thing sounds so good.middle of the road gain wise but dang is it crystal clear.
Great News!
It happens to all of us.
Glad it sounds good.
If Lynch played it, there had to be some merit to it!
Good Luck,
