Hi there,
Here a very bizzar problem. I have TWO MAG 300 amps and both with the same problem.
ps: I use a regulated psu to test the power module (+/- 64V).
The preamp is not connected.
I use a resistive load of 8 Ohms/ 600 W
1. I disconnect the load (speaker).
2. Switch on the amp.
3. Reconnect the load (speaker).
4. Amp works fine...
If I switch the amp on while the load is connected;
The positive supply rail go's in protection (= 3V) and a hefty 400mA is drawn from the psu.
Removal and reconnecting the load makes the amp work as normal.
Attached is the schematic: APC041-1.pdf
Drawing: ACD041 - PCB: APC041/1
I replaced C10 as it was bad.
I checked all other components but could not find a bad one...
Relay circuit is working perfect, when the amp is not connected to a load.
If connected the relay will not engage...
The second amp has the same symptoms...
Help, Hints, Ideas are very much appreciated.
Cheers
Cheers
