Results 1 to 30 of 30
Thread: 5e3 builder from scratch
    Jan 2012
    25
    0
    Hey I'm going to follow
    My 5E3 Build From Scratch
    for my build. I want to salvage most of my parts.
    Could someone tell me if I were to scrap this westinghouse floor radio
    H-168 Ch= V-2118 Radio Westinghouse El. & Mfg. Co. - see als
    would that take care of the trannys and some other parts including the wood.
    the tubes needed for the 5e3 are not listed so I'm not sure if this would be a waste or not.
    thanks,
    Ernest
    Jan 2012
    25
    0
Name:	2012-01-19 12.38.31.jpg
    Chassis Plan printed out and adhered to aluminum sheets (old street sign)
    http://music-electronics-forum.com/a...3-template.pdf
    via My 5E3 Build From Scratch incase you missed it....
    Near Dallas Texas
    3,511
    Received: 185/0
    Given: 104/1
    18
    Couldn't view the schematic unless I joined RadioMuseum. I looked at an ebay auction for an H161 which looks similar. That radio has the OT mounted on the speaker, couldn't read the tube chart. I'm not in favor of destroying the radio to build a guitar amp. The power amp in that radio is probably not more than 5 watts. What tubes does your radio use?
    Jan 2012
    25
    0
    it lists the valves under the picture but I have already passed on that idea. It was a local craigslist ad, went and looked at it and the wood was veneer anyways so I'm bidding on a auction for an old 6v6 amp.
    Jan 2012
    25
    0
    I was able to snatch this up.
    6V6 Tube Amplifier
    comes with tubes
    2- 6V6, 1- 5Y3 and 1- 12AX7
    score
    Jan 2012
    25
    0
    Jan 2012
    25
    0
    Boards ripped to size, now I'm getting some help from a friend with the dove tail jig and router for the edges.
    I'll hopefully get some pics of his projects which include a 5e3, a champ, and a reverb unit made from scratch.
    Jan 2012
    25
    0
Name:	2012-01-21 19.45.17.jpg
    nice dovetail joints
    Jan 2012
    25
    0
    the following are pics of the a friend of mine, PJ's builds. He helped me with the dovetail and my safety for how I'm going to wire this thing.
Name:	2012-01-21 17.59.03.jpg
    Jan 2012
    25
    0
Name:	2012-01-21 17.59.45.jpg
    Jan 2012
    25
    0
Name:	2012-01-21 18.01.35.jpg
  12. #12
    Jan 2012
    25
    0
Name:	2012-01-21 18.00.50.jpg
    and a reverb unit. all built from salvage parts, old amps and such.
  13. #13
    Jan 2012
    25
    0
Name:	2012-01-21 18.00.24.jpg
  14. #14
    Jan 2012
    25
    0
    I'm confused on how to determine what Ohm speaker to use with this transformer that came with my parts amp. How do you tell?
  15. #15
    Jan 2012
    25
    0
    The chassis I'm using parts from comes from an old Ampro Projector. I can find old schematics for Ampro Projectors but none so far that list 2-6v6, 1-5y3, and 12ax7.
    a google search on ampro projector images turns up the specs for a model Stylist 16.
    Ampro Stylist 16
    another stylist 16 manual with schematic
    http://static.cineinformation.org/wp...ice-Manual.pdf
    Lists two 6v6 tubes but a cant find any info of speaker
    http://www.acofs.org.au/part_4_files/Ampro/User-XA.PDF
    The only reference to speaker I can find is 8 ohm in these manuals....is that my answer?
  16. #16
    Supporting Member overtone's Avatar
    Jul 2009
    frankfurt + london
    67
    11
    Quote Originally Posted by ernest View Post
    I'm confused on how to determine what Ohm speaker to use with this transformer that came with my parts amp. How do you tell?...
    Usually I check unknown OTs by running a 1V Ac signal through and check the turns ratio. That will let you know for what speaker the OT was intended for and give you pointers as to how you can use it. Be careful, don't shock yourself. Search for testing unknown output transformers e.g.:
    Finding Unknown Values for Output Transformers
    The other thing I would want to be sure about is: do I have a single ended or a push pull transformer? Pretty sure you have a push pull, but SE OTs with parallel output tubes are not unknown.
    Hope this points you a bit in the right direction.
  17. #17
    Jan 2012
    25
    0
    Quote Originally Posted by overtone View Post
    Yes, best answer I've gotten so far. not sure what any of it means yet but a definite starting point.
    thanks!
  18. #18
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    3,045
    Received: 7/0
    17
    He just means, put a small AC voltage into the secondary winding... measure across the full primary winding ... divide the small number into the big number... take that new number and square it...
    Then multiply that sq'd number by the speaker load impedance (4 ohm, 8ohm etc) and you have the primary impedance.
    EX:
    6vac into the secondary wires... measure the primary wires at say 180vac. Oh and that will knock you on your ass.
    180v divided by 6v = 30 a 30:1 voltage ratio
    30^2 or 30x30 = 900
    900 x 8 ohm speaker = 7200 ohms
    900 x 4 ohm speaker = 3600 ohms
    etc
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  19. #19
    Jan 2012
    25
    0
    Quote Originally Posted by Bruce / Mission Amps View Post
    EX:
    30^2 or 30x30 = 900
    etc
    cool thanks man, I also have it narrowed down by finding someone online using the same ampro amp as his setup.
    http://www.talkbass.com/forum/f15/am...intage-826548/
    without a doubt he confirmed that his which looks damned identical, came with a 16 ohm speaker.
  20. #20
    Jan 2012
    25
    0
    cabinet
    I fit some tan naugahyde to my cabinet over the weekend. 3m super 77 adhesive. I run a graphics dept for a print shop so I have access to the adhesive as well as full run of the maintenence shop where I'm building the chassis. I think it turned out great.
  21. #21
    Jan 2012
    25
    0
    so, decided on a speaker. I didn't have a lot to spend on a speaker at least not right now. I've already given a big chunk to the resistors, caps, knobs, jacks, etc....so I had to save on the speaker...for now.
    so many options, AlNico/ceramic, watt, ohm, so I would love to have a celestion blue, tone tubby, or something like that, I almost went with an old organ speaker with square alnico mag. What I ended up with was very affordable, a celestion G12 that has a modified aluminum voice coil and Hemp cone. I like a bass and mid with early breakup so I hope I'll be happy with it.
    and a oxblood grill.
  22. #22
    Jan 2012
    25
    0
    This chassis is kickin my ass. blew a hole through it with a welder so I'm going to have to make some sides and pop rivet them instead.
  23. #23
    Jan 2012
    25
    0
  24. #24
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Hmm .. the eyelet circuit board appears to have the B+ rail grounded side on the wrong side of the board with respect to the chassis...
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  25. #25
    Jan 2012
    25
    0
    I don't have the board entirely wired yet. doing the best i can with the links below.
    thanks
    Parts list
    schematic #1
    schematic #2
  26. #26
    Denver, Colorado
    3,045
    Received: 7/0
    17
    #2 artwork:
    Doug might be doing that on purpose for some reason... other then just to be different (guess that's OK) I don't know why.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  27. #27
    Jan 2012
    25
    0
    #2 artwork:
    Bruce, I think I may have picked a board style that requires a bit more background knowledge than I have for my first project. I can read how the caps and resistors are populated to the board just fine but now I'm getting into how this wires into the input and output jacks and this was left a bit vague on Hoffmans schematic....I'm sure it's all on his site somewhere though.
    that and I'm using old trannys with extra wires that I don't know what to do with. for instance I have six wires coming out of my output tranny, yet I can only find three on all the schematics.
    Still trying to figure out where I star ground all of this as well. just pick a bolt on the chassis and connect all my grounds to it?
    two unaccounted wires on the PT as well, a brown one and a bare wire?
  28. #28
    Jan 2012
    25
    0
    just gota look...
    Instructions
  29. #29
    Jan 2012
    25
    0
    cont...5e3 first build by Ernest - Hoffman Ampifiers Guitar Tube amp forum
    at Hoffman's site so I can wrap this up.
    thanks
  30. #30
    Jan 2012
    25
    0
  1. My 5E3 Build From Scratch
    By cmattdabrat in forum 5 E 3
    Last Post: 02-06-2012, 03:31 PM
  2. 5e3 Chassis Specs? Building from scratch.
    Last Post: 02-03-2011, 07:59 PM
  3. Building a 6K6 powered 5E3 from scratch
    By Hardtailed in forum 5 E 3
    Last Post: 08-22-2010, 06:17 PM
  4. scratch build 5e3 help please
    By cubby01 in forum 5 E 3
    Last Post: 06-17-2009, 10:22 AM
  5. 5E3 Scratch Build.
    By bkloos in forum 5 E 3
    Last Post: 09-09-2006, 03:33 PM
