Results 1 to 18 of 18
Thread: MODS
    New Member
    Dec 2011
    1
    0
    MODS
    Just curious what everyone's favorite mods are to the stock circuit?
    Dec 2008
    Wernersville, PA
    12,829
    Received: 453/2
    Given: 237/0
    25
    I prefer factory correct circuits.
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,305
    Received: 184/2
    Given: 70/2
    15
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    23
    Senior Member hasserl's Avatar
    988
    Received: 1/0
    14
    My favorite mods would be 4.7uf cathode bypass on the input stages, .022uf coupling caps in the pre, .047uf coupling caps to the power tubes.
    Near Dallas Texas
    3,513
    Received: 186/0
    Given: 105/1
    18
    There are a few updates that everyone takes for granted. The power cord is updated to a 3 wire with safety ground. The "death cap" and ground switch are removed and replaced with a standby switch. The heater wiring is updated to a balanced type with a virtual or actual center tap. The center tap can be connected to the 6V6 cathodes for a little lower hum. The 16uF caps in the power supply are sometimes increased to 22uF for availability reasons.
    There are several mods to the coupling caps that are frequently done because of excessive or flabby bass. See Hasserl's post above.
    Grounding can be an issue. Everyone seems to have their own opinion on how to get it right. Good luck with that!
    Tube swaps can be done to change the gain and/or headroom.
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Quote Originally Posted by Steve Conner View Post
    Man Steve, it's a good thing you aren't a plumber...
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Supporting Member deci belle's Avatar
    Jan 2010
    Santa Fe, NM
    374
    10
    Please tell me about that, Loudthud!
    Near Dallas Texas
    3,513
    Received: 186/0
    Given: 105/1
    18
    Preamp tubes can inject hum from the heater circuit into the signal for a number of reasons. One is that the heater wants to emit electrons (because it's a hot glowing metal) and those electrons can be attracted to the cathode. Not a problem if the cathode is grounded or fully bypassed to ground with a big capacitor.
    If the cathode is always negative with respect to the heater, the cathode will repell those electrons. This is accomplished by making the heater slightly positive, about 20V. This reduces the 60Hz hum that sounds like a low organ note, not the 120Hz buzz that comes from the power supply. The amount of reduction will vary from tube to tube.
    Jan 2010
    Santa Fe, NM
    374
    10
    Okó now I know why, Loudthud!
    So on a 5E_, the center tap shares the ground connection with the cathode/resistor bias circuit?
    Is this the green/yellow 6.3v center tap?
    Near Dallas Texas
    3,513
    Received: 186/0
    Given: 105/1
    18
    Quote Originally Posted by deci belle View Post
    Ok— now I know why, Loudthud!
    Your wording makes me a little nervous. In this thread, post #4, I posted a layout of an amp with elevated heater supply: http://music-electronics-forum.com/t12663/
    Different output tubes were used but it's basically a 5E3. Note how the green yellow striped wire goes to the plus side of the cathode bypass cap of the output tubes. The layout also shows a good grounding scheme.
    In this thread, post #10, I posted a schematic of a 5F1. That transformer didn't have a center tap on the heater winding so a pair of 100 ohm resistors were used to create a virtual center tap. http://music-electronics-forum.com/t16311/
  12. #12
    Jan 2010
    Santa Fe, NM
    374
    10
    Yes, Loudthud. I see the ctr tap in the first example (5E3) and the two 100Ω in the second example (5F1) connecting at the same spot: the positive side of the cathode bypass cap for the power tube(s).
    I did not understand which side of the cap you meant, which IS a good reason to be worried. I've only been at this for two years and am just in the middle of my first scratch build. Thank you so much for including the links to both examples!
    In my case, even though I have a heater ctr tap, I want to ground the 100Ω resistors per example two. My PT came with a warning NOT to use the heater ctr tap unless it was on my schematic (since I drew my schematic it isn't there haha!!).
    Last edited by deci belle; 02-01-2012 at 04:29 AM. Reason: got my examples mixed up!
  13. #13
    Near Dallas Texas
    3,513
    Received: 186/0
    Given: 105/1
    18
    Use one or the other, not both. If you hook one to the cathodes and ground the other one, you will short out the bias for the power tubes! (That's very bad!)
  14. #14
    Jan 2010
    Santa Fe, NM
    374
    10
    Haha! I'm joining the ends of the 100Ω Rs and that'll go to the positive side of the pwr tubes' bypass cap. I'm lifting the heater CT.
  15. #15
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Adding to this... you can just lift the filament winding's center tap (usually green/yellow here), then solder a 1/2 watt, 47 to 100 ohm resistor on the end of it and solder the other end of the 47 to 100 ohm resistor right to the positive end of that same cathode bypass cap previously mentioned.
    You don't really need the 1/2 watt resistor but I always do it in case there is short from lug 2 to 3 somewhere on one of the power tube sockets.....and my small brain makes feel like the 1/2 W resistor could at least blow open if too much Hi-V goes into it.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  16. #16
    Jan 2010
    Santa Fe, NM
    374
    10
    Bruce, why is the bright channel's coupling cap .047 and the normal channel's cap .022 on the Tweedy specs? Guess you can tell I haven't wrapped my head around the 5E3's volume/tone circuit yet!
  17. #17
    Denver, Colorado
    3,045
    Received: 7/0
    17
    Not sure where that info came from unless you might be talking about someone's mod and they just used my altered artwork... which was altered from old Fender art.
    Using smaller coupling caps to the volume pots is an old and true way to rid some of the flabbiness from the 5E3 circuit.
    The normal channel is very flat and dull sounding to me so a smaller cap vs the bright channel is a good thing to try.
    I've even gone from the stock .1uF to as a low as .0075uF and the amp still sounded really good.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  18. #18
    Lifetime Member
    4,425
    Received: 401/1
    Given: 3/0
    21
    I personally like these:
    Some Blindingly Obvious Things...
  1. VHT mods? Anyone?
    By xSweep in forum Mods & Tweaks
    Last Post: 04-09-2009, 04:21 AM
  2. Your opinions on a few mods
    By pine in forum Mods & Tweaks
    Last Post: 12-25-2007, 08:15 PM
  3. Anyone doing mods on these yet?
    By JJGross in forum Mods & Tweaks
    Last Post: 08-07-2007, 10:18 PM
  4. ds1 mods
    By mytech1 in forum Guitar Effects
    Last Post: 02-03-2007, 04:09 AM
  5. Let there be mods....
    By escyrs2000 in forum Mods & Tweaks
    Last Post: 08-25-2006, 09:22 PM
