Anyone know if DiMarzio was in the habit of actually winding the two coils on their rail-style single coil size pickups in opposite directions instead of just doing The Usual?
Actual Reverse Winding
Originally posted by fieldwrangler View PostAnyone know if DiMarzio was in the habit of actually winding the two coils on their rail-style single coil size pickups in opposite directions instead of just doing The Usual?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I haven't seen the bottoms of a dimarzio bobbin, but it could be the same as the top. I think I will have to try this! Thanks for the idea!
Ethan
Ethan
It really doesn't matter which way you do it.
With single coil pickups, the start is usually ground, and they are wired in parallel. So by reverse winding, you keep the grounds close to the magnets for less noise. With series connected pickups it doesn't matter since the start of the second coil is not going to be at ground.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I've rewound some 70s P-Bass Pickups.
They do the true reverse wiring.
They were wound with PE.
From the Pot, the Hot Lead, wired to the start of the CCW Treble string bobbin (North Up).
The finish of the CCW bobbin tied to the Start of the CW Bass String bobbin(South Up).
Then the finish of the CW bobbin ties to Brass Ground Plate.
That could be turned around easy enough if you wanted the start of one coil grounded.
So the Options on wiring Buckers are pretty much endless.
Good Luck,
B_T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Originally posted by big_teee View PostThey do the true reverse wiring.
The original question was about the DiMarzio dual rail pickups. They are wound in the same direction. So are the Duncan dual rail pickups.
The only reason Fender wound any reversed is because of the magnets picking up noise.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostIs there a such thing as false reverse wiring?
Knit Pick if you want."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
But why would you want to do this for dual blade Strat humbuckers? Or Gibson humbucker for that matter? What benefit do you expect from it?
RWRP is not anymore "true" than reversing the wires on one coil, as Gibson does. The electrons don't care if they are going from the inside to the outside or vice versa. It's only done because they are winding right on non grounded magnets.
Please don't make it into something "magic."It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostI'm talking about the wording "true reverse wiring". Either it's wired in reverse or it ain't! There's nothing "true" about it. That makes it sound like it's up on a pedestal, like "true bypass", which is another thing made more important than it is.
Bob Palmieri
Originally posted by fieldwrangler View Post(besides the issues of capacitive coupling between the inner winds and the cores)
I tried winding my humbuckers with reversed coils for a while. It didn't change the tone, and got to be confusing when winding a bunch of pickups, so I went back to winding them all CCW.
You can make some tests though. Just take one bobbin in a humbucker and flip it over and swap the outputs leads. Now it's reverse wound.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by fieldwrangler View PostAs they used to say on Perry Mason, "The Court is Yours..."
First off: In the "strat blade humbucker" design, capacitance will dominate (hot tip ). the bobbin is quite thin(distance) and the blade is a massive "Plate" (area)... We all know the formula for capacitance. (Actually, It's in my notes... I couldn't find it)
As a note: the blades will be grounded to prevent electrostatic noise. This is basic, but an important assumption.
So, the difference between "faux RWRP" and real "RWRP" is capacitance.
Distance and Area are important to capacitance, but we also need to take into consideration "electrical potential". For instance: if we ground the "start" winding, the rest of the coil is essentially "shielded" from the capacitance of the blade. The blade and the winding are at the same electrical potential... So, that might be the way we want to go to minimize capacitance. But, if we want the "finish" to be grounded for shielding of external electrostatic noise purposes, then we have developed capacitance (to ground) on the inside and outside of our coil...
So that is one coil of a humbucker. The grounded side coil and it's two possibilities. up to the designer.
Now for the other coil in a humbucker configuration...
If we only use the standard "faux" RWRP... Then we have no choice, we wire it up based on our decision for the first coil.
The reason I like Bob's question so much is: It made me realize we DO have the choice of which part of the coil to put next to that massive plate! So, here is the question: do you want to have the "hot" part of the winding next to that Blade? Or do you want the "series connection" part of the coil next to that Blade? Which part of the second coil is at greater electrical potential?
Its up to you the designer. As Bob points out, we actually do have a choice!
Thanks Bob!
Ethan
Notice the ratio of coil to core. Now look at a Strat pickup. Fatter coils and also fatter cores.
Also, how about these pickups?
No "massive" plate. Lots are air space between poles.
And let's note that Fender pickups do not have grounded magnets. So it doesn't matter if the start or finish is grounded. It's very easy to demonstrate for yourself. Take a single coil pickup and wire it to a polarity reversing switch. Now switch the switch back and forth. Do you hear a change in tone? You wont.
Also having the finish of the coil at ground does not provide shielding. Once again, how many turns do you have to go to get away from ground potential?
Now, let's wind both coils the same and wire them finish to finish. Now where is the start of the second coil. it's at the "virtual" finish, since it's at the end of our series connected coils. Any benefits here?
Since you have obviously never tried it, go ahead and try it. Here's an EASY way to try it.
Here's a dual rail Strat pickup. Note the really thin blades.
So let's pretend I wound this pickup, and both coils are wound the same.
Now lift one coil off the blade, like this, and flip it over. Now it's wound in reverse.
Real easy to test. Do you know what you are going to hear different? Nothing. But by all means try it yourself.
See? it's one big coil. It doesn't matter what direction the second half is going. That only matters for hum cancelation.
We can see that it's probably a good idea to have the blades grounded, and the start also grounded. But now we have the second coil. It's start is going to NOT be at ground.It will be thousands of turns in. But it will be next to the grounded blade. See the conundrum? So if your start being ground is good for capacitance, you just flushed that down the toilet with the second coil, since it's start will never be anywhere near ground potential. Do you see it now?
As a designer you can decide you want green magnet wire. That also wont change the tone, and will just look ugly!
I say to you to try it out. I have many times. It was not worth the effort to reverse wind one coil in a humbucker, so I stopped doing it. Ask yourself why its not done?
The original question was does DiMarzio do it? No, they don't. Why don't they? Why doesn't any of the pickup makers do this with humbuckers? because once you are at the second coil, it doesn't matter unless they are wired in parallel.
Here's how this question should have gone; "Has anyone tried winding a blade humbucker up RWRP, and did it make any difference in tone?"
The answer from me is, yes, and no. And my blade humbuckers have much more massive blades than dual rail strat pickup.Last edited by David Schwab; 02-15-2012, 04:41 AM.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
