I read and performed 2 blue guitar mods upon testing the second one which was replacing c18 with a 820pf silver mica cap, something must have touched the main board because the main fuse burned. I replaced the fuse and now I have no clean channel and the lead channel is very fuzz box sounding. Also the volume pot shafts are sensitive to the touch. I tried changing out the fist two 12ax7's and checked the boards for any obvious signs of burns or loose connections. I have some experience with amp building and such but I don't know where to start. I feel naked without my amp! HELP Please!
Peavey Classic 50 HELP!
There are so many classic 50 models that you should contact peavey, 601 483 5365 and try to get the exact schematic, using the serial number, and post it here.
I am making an educated guess that the low voltage plus minus supplies may be damaged. BUT that is just hot air until you get your schematic and take some readings.
Circuit tracks may be broken or damaged, or there might be a bridged solder connection, (???)
There are only two versions of the Classic 50. The original which had no effects loop, and the version a year later where they added an FX loop. That same Classic 50 has been made ever since, 20 years now. Other than that loop, they are the same.
There are other versions of the Classic, and they may even be 50 watt amps, but they are NOT Classic 50 amps.
I am with AMU here, look closely at the ribbon connectors. ANy chance one of them is off one pin?Education is what you're left with after you have forgotten what you have learned.
There are only two versions and they are very easy to tell apart. You either have a 6L6 amp or an EL-84 amp. The mods are Steve Aholas on the Blue Guitar page. I would undue the mod and see if you can get it back to original then start over.KB
Originally posted by Enzo View PostThere are only two versions of the Classic 50. The original which had no effects loop, and the version a year later where they added an FX loop. That same Classic 50 has been made ever since, 20 years now. Other than that loop, they are the same.
I don't believe you.
I think there are way more than 2 versions.
Fine. Post them. I am willing to be educated.
If they don't say "Classic 50" on them, though, they are not "Classic 50" amps. So if you are thinking about the old Classic from the late 1970s or the later Classic VT and the Classic VTX, stop, they are not Classic 50 amps, they are 50 watt hybrids. There is also the Classic 50/50. it is not a Classic 50, despite the similarity in names. It is a dual power amp, no preamp.
The Classic 50 came in 2x12 and 4x10 versions, but the amp was the same, the schematic the same, in fact the schematic shows both on the legend. The amp chassis in the head version is also the same. If you want to call that three models, go ahead, but since when you brought up your thought that there were many versions, you were concerned with finding the schematic to match, and in that case, there is just the one. With or without the FX loop added.Education is what you're left with after you have forgotten what you have learned.
Originally posted by audiosalvage View PostOk, this is interesting but if I plug into the effect return, I get a steady clean tone. Also when I'm plugged into the input, lead channel, you cannot completely silence the volume with the master control. It kind of fades out at about 8:00 then louder again. Could it be a pot?KB
