Can you guys show me some photos of your amp builds?
  • #46
    My first scratch built Plexi 50 bass/lead clone 86/87 circuit.
Name:	plexi 50 1.jpg
Name:	plexi 50 2.jpg
Name:	plexi 50 3.jpg
Name:	plexi 50 4.jpg
    • #47
      Wow Steve, You can even control the room temperature with this one:
      Love the vintage look.
      • #48
        As a frugal Scotsman I find that 12W of heat from an EL84 is about right for keeping the frost off ma sporran.
        I completed that amp by painting the faceplate gold, the speaker grill black, and changing the knobs.
        • #49
          Steve, what make/model speaker is in that NinjaCorvetteGold amp? It has an interesting looking cone and surround, like a full-range hi-fi speaker.
          Now Trending: China has found a way to turn stupidity into money!
          • #50
            It's an Eminence Beta 8, which is a full-range PA speaker right enough. Maplin had them on special, and I had one kicking around looking for a use. It sounded better than the Elac radio speaker that was originally in the amp.
            You can read more about the project here.
            scopeblog » Ninja Corvette Hybrid
            • #51
              Ah OK, I see the purple cone from behind and the label of course.... The new 8A's don't have the bigger paper dust cap, I wonder if it changed the sound any?
              • #52
                I believe mine is an 8A. The dust cap is the same size as the end of the voice coil, hard to see how they could have made it smaller.
                • #53
                  OK maybe I'm seeing things looking through the grill...the opening is for a 10" speaker and it made the dome seem bigger then 2". The speaker is rated for 225 watts!!
                  • #54
                    So many beauties i'm ashamed with my tiny toy, but it's fun and i like it. It's a single ECL82/6BM8 amp.
                    • #55
                      Here's a 5E3 based amp with switchable fixed/kathode bias, modified voicing and a couple of other things:
                      and this is a groud up 1x12" + 2x8" 2x6L6 harp amp
                      • #56
                        Nice work Bluefinger.
                        Your two tone tolex covering design is very attractive.
                        Cheers,
                        Tom
                        • #57
                          Cool thread! Here's one of mine:
                          And here's the build thread if you're interested: I'm gonna build a 6G3 Deluxe! From scratch! - The Gear Page
                          • #58
                            Matchless Lightning clone Hammond organ amp conversion.
                            • #59
                              First Build
                              My first attempt was a 5E3 with Triode Electronics parts.
                              Brother-In-law had access to a CNC punch press and fabricated the chassis.
                              Red oak was left over from a home remodeling project.
                              Learned as much about cab building as I did amp building. I now know what not to do.
                              I use the Vintage AC adapter (thanks R.G.) from the GEOFEX site to tame
                              the high B+ and heater voltages due to the Triode Electronics transformers.
                              Have parts to do the mods but it's a lotta fun as is.
                              a sign on the desk of Suzanne Schroeder, collector of bureaucratic gobbledygook, AP wire story, Sarasota Herald-Tribune, July 3, 1973
                              “I know that you believe you understand what you think I said, but I’m not sure you realize that what you heard is not what I meant.”
                              • #60
                                This one's a Weber Tore-Vibe, standalone reverb unit with bias tremolo. Only a little tweak to the original schematic.
