behringer ddx3216 problem help needed
  • behringer ddx3216 problem help needed
    hello group;
    i am new to the list and need to ask a few questions about my behringer ddx3216.
    the unit turns on and all leds flash on then go off
    unit boots up to the welcome message ---( DDX3216 AUTOMATED DIGITAL MIXING CONSOLE )
    shows firmware V1.1
    the faders position at 0-
    the preset display flashes +1 8. and goes off ---that as far as it goes.
    i am wondering if it needs a firmware upgrade or presets loaded in.
    i performed the factory reset --it works as normal ending with the Lcd showinG ( FADER CALIBRATION DONE) AFTER THAT I CAN NOT GET ANYTHING ELSE DONE.
    is this the point that i should try to load presets?
    i have tried to access firmware load in through the rs232 port but get no response
    the preamp section works, when i plug a mic in i see action on the signal / clip led
    is there a diagnostic procedure?
    thanks for any halp
    bobby
    any help greatly appreciated
    bobby pridgen
    It is most likely to be bad caps in the power supply, but be forewarned: those mixers were riddled with problems.
    John R. Frondelli
    "Mediocre is the new 'Good' "
      hi John;
      thank you very much for the reply. i read that there is a link to a video or instructions for recapping the psu. i searched but cannot find anything. would you have any suggestions?
      best regards
      bob
        Some other posts regarding the power supply:
        http://music-electronics-forum.com/t24165/
        http://music-electronics-forum.com/t27237/
        And from another forum with some recap pics about halfway down: Mixer is dying. Time for a mod.
          Originally posted by flashpump View Post
          hello group;
          do you have this display +1 8 even after the firmware reset ??
          My console also does this thing, but this must be any hint to EProm / Flashprom trouble. My console doen´t store presets in flash anymore.
          Does anyone have more informations about this error codes ?
          I´m also messing around with my anaout-board, and have seen several messages in the mean time.
            hello group;
            i am new to the list and I have problem with my DDX3216.
            And my problem its
            and
            Can somebody help me!???
            tnx
