Tapped Pickup Wiring Idea
  • Tapped Pickup Wiring Idea
    Hey guys,
    any reason why this wouldn't work? Am looking at something wrong here?
    I also thought that it may be possible to wire the finish lead permanently to ground and then run the tap to a switch that, when activated, grounds the tap, thereby shunting the extra, outer windings. The reason I want to use the start wire for my positive output is because my pickups seem to have less buzz and hum when I do. Thanks.
    Originally posted by raygun85 View Post
    Hey guys,
    [ATTACH=CONFIG]17652[/ATTACH]
    Yes that will work.
    If feeding the start lead, and winding over Rod magnets?
    Make sure the magnets are insulated well and the wire doesn't short to the magnets.
    Good Luck,
      Thanks for the reply. Actually, I'm winding a P-90 type pickup with screw pole-pieces. So there shouldn't me any trouble with the wire toughing the poles. Thanks again for the reply, just wanted to make sure I wasn't crazy.
