Greetings! My Yamaha EMX660 mixer's limiter light indicator (the one on the power amp 1 side) is on full-time at power up and I have NO output to my speakers.
The unit powers up as normal and the fan still works. My mixer was returned to me with this problem after loaning it to a friend, who loaned it to another with my permission. So, I have no idea of the circumstances that caused this problem, and both "friends" plead ignorance. My guess is that someone in their band didn't know what the hell they were doing and plugged something into my mixer when they shouldn't have, or where they shouldn't have, or just plain didn't follow PA system 101 causing too much of an overload on the mixer.
The owner's manual only describes the purpose of the limiter indicator and the troubleshooting section doesn't cover this particular problem. I checked for output to my speakers in the main-main, main-monitor, and bridge configurations (turning the mixer off before switching positions of course) and the problem remains. I took the unit apart to visually inspect all circuit boards and their components, fuses, and traces for signs of being blown, burnt, arcing, etc ... and everything looks fine ... as far as I could see with the naked eye and a flashlight.
Internet searches revealed that I more than likely have a blown power amplifier. Is there a quick and easy way for me to isolate this problem to being a blown power amplifier? If this is the case, can anyone tell me approximately how much it would cost to have an electronics technician replace it for me (part & labor charge). Thank you kindly!
