Anyone out there got great ideas to convert organ's to guitar amps. Really not interested in re-making one from scratch. Just re-engineering what's needed with what's already there. I have #3 Conn 541's from early sixties and have the schems. Unbelievably they have transistors in an off-board preamp. Would like to possibly reuse the 12 au7's used for the keys in the preamp. Maybe as a second valve (cause 12au7's are about 20% amplification) I'm trying to find a way to also reuse the leslies as they would easily fit into the bottom of a 4-12 speaker cabinet along with the vintage 2-12's in the top. I need to really get the tone stack figured out, the tube preamp figured out, and a way to add a master volume and volume. Any help will clear out my garage.
Organ Conversions - Guitar Preamp/Master Vol/ Tone... Help!
Welcome to the forum.
Check out this sub-forum under Guitar Amps.Lots of organ amp conversions.
Conversion Projects
Good luck.
The reason I started this was after thorough scouring this site. I may have missed some things, but really have seen a need to almost map out the process. The conversions have gone fromm just using the organ as parts for a whole new build. I've also seen where there has been a factory preamp used in front of the AMP. I've also seen examples of tone stacks added without explanation. So any one with more experience with modding these I have #3 conn 541's, a Silvertone4784(looks like Magnatone 410 tremelo), and a couple solid state Conn's with reverbs, Rola speakers, and Leslie's.... People here have started almost just bringing these to me. Thanks for any help you can give, my wife wants me to start on remodeling the dinning room soon....
Thanks, Yes I have scoured it several times before calling out for help.. It is good overview and outline for planning a build. I think it is a great source for making an almost new build. I was lost at some parts because the author is creating a broad view, but getting specific on points that would be great as wiring examples. I really think its a great article, but it has left me wanting more.... I Know it's time consuming to post hand drawn schem's, but I've spent too much time looking at pictures(speak a thousand words) than putting together a word problem in my head. With all the old organ's headed for the scrapyard now-Baby Boomers don't have room for Ma and Pa's '60's Organ- It would be cool to see "Turning Organ's into Guitar Amps for Dummies". I know it's been done but wish that there was a more meat and potatoes documentation of the process. I've managed to fix tube amps and know my way around electronics, just not as keen on theory to practical application.
The obvious!! Thanks hasserl! Should of thought of this... I got actual printed Schematics from a Organ Service Co. The Sears one is 81/2x11", but the Conn's are large fold-outs with several pages. It will take some time to figure out how to scan these in pieces, but I will post at least the Silvertone right away. It is probably the easiest because it has a piezo microphone that amplifies a Reed air chamber organ. It may have a good enough preamp at least, just need to add tone and tremelo controls. Will post these as soon as possible.
Here's the Silvertone Organ Amp Schematics also Magnatone(Tremelo curcuit similar)
Here is the Schematics for the Silvertone Organ. I added the Mag 410 cause the tremelo curcuit is so similar. I heard the silvertone organ was made by Thomas organ(Estey) This is my first time posting so I hope it works.......
So you have a single ended 6AQ5 (electronically equal to a 6V6 but in a smaller bottle w/ 7 pins) amp with 3 gain stages and tremelo, cool. You'll want to make sure the filter caps are fresh, no sense in building something with 40 year old filter caps. You'll need to add a 1/4" jack for the input; the resistance of R1 is kind of low for a guitar amp, it will load the guitar pickups down, 1M would be better. The input stage should be converted to a common cathode style stage, i.e. add a cathode bias resistor and bypass cap; I don't know what the Flute & String marks indicate, but most of that between V1A and V2a can be eliminated, but leave C1. You could just sandwich a Fender style tone stack/Vol between V1A & V2A, that would allow you to retain the current vibe wiring and the nfb circuit. The amp should have plenty of voltage gain to drive the 6AQ5 into full saturation, could be a great sounding little amp.
Take a look at Fender schematics and start redrawing your schematic to incorporate some of the circuits from those amps. Bring it back here for review from the group.
I Just picked up a Third Silvertone Organ amp chassis and this one dates to 1969(Schumacher transformer). I tested it with a guitar through the mic input and it worked. This one differs from the others because it has a trim-pot added for the tremelo intensity. Only problem is it of course is weak as a guitar amp as the input is not matching for the guitar impedance. The Flute/string switch is just a bass/treble switch almost a 'bright' switch.
Originally posted by scrimpus View PostDoes anybody have a schematic for this organ? The above links don't seem to work for me.
A batch of files was lost.
Here you go.Last edited by Jazz P Bass; 08-03-2013, 02:53 PM.
