Vintage Uni-Vibe info request
  • Vintage Uni-Vibe info request
    I'm looking for a part # or replacement for the power indicator lamp holder. Given the value of the pedal, I don't want to stick just anything in there. Can someone point me in the right direction?
    Update: Mine is actually a Jax Vibra Chorus, which might not use the same indicator.
    You won't find an exact replacement, but if I remember correctly the one that Antique Electronics carries will look very similar to the original. Try part number PL-110 with a red jewel.
      Thanks for the suggestion. Unfortunately that one requires a larger cutout than the original. Mine still has the lens intact but is missing the plastic body where the part # would've been. I guess worst case, I could hang a bulb under the lens with some heat shrink tubing.
