Results 1 to 20 of 20
Thread: Anyone Recognize This Noble Amp from the 50s?
    Member Jecarroll7's Avatar
    Apr 2010
    Atlanta GA
    144
    11
    See attached pictures - I have a Noble accordian/guitar amp from the 50's? from the Noble Accordian Company in Chicago.
    As I understand it, Ampeg, Valco, Danelectro and Supra all may have manufactured amps for Noble under OEM agreements.
    If I had to guess I'd say Ampeg as the regulator/power stage looks remotely like the Ampeg Jet J12B, although the knobs look like Danelectro
    Problem is a resistor between the OT center tap and pin 4 of the 6L6 power tubes is fried beyond recognition.s
    Trying to track down a schematic or value for the resistor.
    Attached is a photo of the front of the amp, the other is of the fried resistor in circuit. Never blew a fuse, I think the resistor just gave out. Looks like 1/4 watt but other schematics of similar design suggest the resistor should be of heavier wattage.
    Additional Information - There is a stainless steel control panel with Pots, Resistors, Caps and (1) 12AX7 above the speaker
    The aluminum chassis with the below tubes is below the speaker. The two are connected with an audio wire, and a 5 prong multi wire twisted voltages cable.
    The amp uses the following tubes:
    V1 - 6SJ7
    V2 - 12AX7 (plus another one located on the control panel)
    V3 - 6SN7
    V4/5 - 6L6GC
    V6 - 5Y3
    I hope someone has seen this before. Any help is appreciated. Thanks
Name:	Burnt Center Tap Resistor.JPG
ID:	18116   Click image for larger version.
Name:	Front Photo.JPG
    Senior Member Jag's Avatar
    500
    15
    Did you see this, dumb.org ’57 Nobel Twin Twelve?
    Maybe look for a Dano 1396 schematic. I'm on my iPhone right now so couldn't really dig too much.
    500
    15
    Apparently Danelectro also built the Silvertone 1396. Does this schematic look similar to your amp, http://www.webphix.com/schematic%20h...rtone_1396.pdf?
    Apr 2009
    689
    Received: 1/0
    12
    I ressurected a defunct 1396 a few months ago. What an amp.
    Gut shots here
    Judybox Revival: Resuscitating A Silvertone 1396 Twin Twelve
    500
    15
    Nice one PD! I've got a 1395, real odd-ball but has a really cool tone.
    Apr 2010
    Atlanta GA
    144
    11
    Jag,
    Appreciate the help. Do you happen to have the schematic for a 1395? The 1396 got me close, but my amp has a single speaker and I'm hoping the 1395 schematic is a closer match.
    500
    15
    I've never been able to find a schematic for the 1395, it seems to be a pretty rare amp. It's basically a 1394 in a 1396 cab with a 15" speaker. I've never found a schematic that matches exactly. I've been meaning to draw my own but never seem to get around to it.
    500
    15
    That picture is one of the 6L6's? That resistor looks like it goes to ground, it may be the same ground as the OT CT but it would be more accurate to say it goes to ground than the OT CT.
    Can you post a more inclusive picture of the guts.
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    A better photo would be great. I don't think that the resistor or the output transformer lead are connected to the grounded mounting lug of the terminal strip. It's hard to see, but it looks like it's one over from the grounded one.
    In any case, the resistor connects to pin 4 of the tube. Are both pins 4 connected together on the 6L6's? Is there only one of these screen grid resistors?
    Apr 2010
    Atlanta GA
    144
    11
    Jag,
    There is a Sams Photofact schematic available for the 1395 at https://www.samswebsite.com/en/photo...ndex/id/150701
    Apr 2010
    Atlanta GA
    144
    11
    Okay, replaced R25 2.2K resister with a new carbon comp 1/2 watt
    Okay, replaced R25 2.2K resister with a new carbon comp 1/2 watt, played fine for a couple minutes and then toasted the new resistor. Did not blow the fuse.
    Schematic attached.
    1/2 watt seems light supplying two 6L6 tubes, but then again the resistor I pulled out was 1/2 watt and lasted 50+ years.
    Did the old carbon resistors handle more current relative to their rating? Or do I have something else going on in the amp?
    Not seeing anything obviously wrong with other resistors/caps, tubes all check out on my Hickok. Plug in a 1 watt and follow the smoke?
    BTW: The resistor is not soldered to a grounded lug.
    Attached Files Attached Files
  12. #12
    500
    15
    Something is causing a lot of current to go through that resistor. My first guess would be a short in one of the output tubes (sorry, I should have thought to mention that before) but could be a bad filter cap or OT.
    Build a lightbulb limiter (you can do a search on this site for instructions), pull all tubes, except the rectifier, and power up with the limiter in line. If the bulb lights brightly, you've got a short somewhere and my bet would be a bad filter. If the bulb is dim, it's probably a tube.
    Give that a try and let us know what happens.
  13. #13
    Apr 2010
    Atlanta GA
    144
    11
    It Seems To Be Working, its been playing now for about 20 minutes.
    Replaced two filter caps which tightened up the ripple quite a bit.
    I didn't build the limiter, but that is on my list. I did pull the tubes which stopped the current draw long enough for me to check caps.
    It would be nice to have an LC analyzer with load/leakage testing ability, I see one in my future.
    Appreciate the help from everyone, especially Jag.
  14. #14
    Junior Member
    Jan 2009
    7
    0
    Quote Originally Posted by Jag View Post
    Did you see this, dumb.org 57 Nobel Twin Twelve?
    This one belongs to me. I actually think it's more like a 1392 based on the schematics. The RMS output is about 35W. I had a cap short at the choke recently. It blew out the choke. They are now available on Mercury Magnetics for replacement if you ever require one - they cloned mine. Anyhow, this amp is amazing. Here it is in action: Old Bottle Black - La Morena - Floyd's Place, Seattle - 04/20/2012 - YouTube
  15. #15
    500
    15
    Cool!
  16. #16
    Junior Member
    Jan 2009
    7
    0
    The 1396 was available in '59, from what I can determine. This is a '57, at least based on the pot codes, so it's more likely the predecessor, a 1392.
  17. #17
    New Member
    Sep 2013
    Phoenix, AZ
    2
    0
    Vintage Noble Amp
    Judging by the numbers on the speaker it's an early sixties. Just had it cleaned, re-tubed and minor repair to input jack. Sounds really nice. No reverb but does have foot switchable Tremolo. You can also "jump the lead" using patch cable to connect the two channels. That really made a difference. Can control both volumes and tones. Very cool little amp. Bought it at vintage shop in VA about 10 years ago. If anyone knows anything more about it I would love to know. Don't know what variety it is, Magnatone or Ampeg. I am curious.
ID:	25005Click image for larger version.
ID:	25006Click image for larger version.
ID:	25007Click image for larger version.
ID:	25008Click image for larger version.
  18. #18
    Junior Member
    Jan 2009
    7
    0
    @jp55, that's a Magnatone model. Don't get rid of that... it's worth a lot more than the others, particularly if the tremolo is actually a vibrato (raises and lowers the note frequency rather than the volume).
  19. #19
    New Member
    Sep 2013
    Phoenix, AZ
    2
    0
    Cool man, thank you for the info. There wasn't much info available 10 or even 5 years ago. So this is really good to know. And as far as the Tremelo goes, I'm not really sure about whether its a vibrato or tremolo. The face plate says tremolo. There is a speed control knob and an intensity control knob. When I bought it the own of store (Action Music in Arlington VA) told me it was a 1958, but speaker doesn't support that. Perhaps the original owner swapped it out. I will make a video recording of the amp and upload it to YouTube then post the link
    JP
  20. #20
    Junior Member
    Jan 2009
    7
    0
    Quote Originally Posted by jp55 View Post
    JP
    Hell yeah, that would be superb. I've attached a photo of my Noble just for reference, mine is based on a DanElectro 1392 from 1957. They varied so much over the years. There's another Magnatone based Noble on ebay right now for only $150, it's probably worth twice that and sounds ten times that.
  1. unknown 50s amp
    By ringling in forum Vintage Amps
    Last Post: 11-15-2013, 12:57 PM
  2. Anyone recognize this fender cab?
    By AndyM in forum Vintage Amps
    Last Post: 10-12-2011, 09:16 AM
  3. Help! Anyone recognize this amp head
    By ddragg in forum Vintage Amps
    Last Post: 10-14-2010, 04:09 AM
  4. Noble High Fidelity?
    By redhare in forum Vintage Amps
    Last Post: 07-06-2009, 11:04 PM
  5. Do you recognize the maker of this guitar?
    By LtKojak in forum Guitar Tech
    Last Post: 08-11-2008, 09:50 AM
Tags for this Thread
