Crunch/Lead Channel Differences - Bugera 333XL 212
  • Crunch/Lead Channel Differences - Bugera 333XL 212
    Hi, again..
    I am still working on shaping my tone, but I have a fairly huge difference in the Volumes between the Crunch and Lead channels. The crunch has good tone and breakup but when I switch to the lead channel it has more of a distortion over distortion sound that is not a solid defined tone.
    I have placed new JJ EC83S tubes in and have switched them around and I still cant get the one side to be clean and defined.
    I am running a new set of the Bugeras 6L6GC Matched Quads in it.
    I am wondering if there isn't a bad something on the board that may be causing this issue/s. I have noticed since I owned this amp the Pre -volumes for each channel has gotten further offset having to raise the crunch more to equal the Lead at the same volume levels.
    Thanks for any ideas..
    Bugera 333XL 212 Combo 2009 Factory Mod KT-77"'s JJ ECC83S
    Roland Cube 20
    Schecter BlackJack SLS C1 SD Blackouts
    Martin DX1AE Acoustic
    Bad Monkey OD
    Line 6 M9 Stompbox
    Behringer EQ700
    Live Wire Cables
