Replacement Power Transformer for a Univox Amp
  • Replacement Power Transformer for a Univox Amp
    Hello All
    I have a Univox 155 amp that has a transformer that hums and I would like to replace it. What is a suitable replacement for this amp that has a separate tap for the rectifier, which is a 6CA4?
    Thanks In Advance
    Have you replaced the power supply caps yet? If not, do that first and see if it still hums.
      It may also be a lamination hum.(which could be aggravated by the bad caps)
        Yes, I have replaced all of the power filtering electrolytics, and even stepped up the values a little.
          Bump - anyone got any ideas or past experience with this type of amp problem?
