Bugera 333XL Channel Switching problem
  • Bugera 333XL Channel Switching problem
    Hello,
    The Channel switching on my Bugera is randomly failing.
    When I swicth to channel 2 or 3 (with or without the footswitch plugged in) it switches to the channel for an instant then it goes right back to the clean channel.
    Somtimes it does this as soon as I turn the amp on (it does this with the amp in Stand By too) so I don't think it can be a heat issue, somtimes it may take an hour before it happens but it will also randomly work a few times even after it has failed.
    Has anyone else seen this issue?
    Thanks in advance,
    Ray
    Originally posted by raynman View Post
    Hello,
    Thanks in advance,
    Ray
    Pretty much all popular amps use mechanical relays, LDRs, or FET switching.
    Your description reminds me of mechanical relays.
    The contacts wear out or slowly burn out. Cleaning is futile. You need new relays.
    It's great to install sockets, like Hi Rel gold plated machine pin type, so you can unplug / plug in new relays.
    OR it could just be bad solder connections too. But probably relays...
      Thanks for the information.
      I took the amp to a repair shop(not the first time with this amp!).
      The tech ordered a new Digital module board from Bugera.
      He has it under test right now. I will update when I get more info.
      Thanks for your responce
        I missed out on the thread, being I relocated, Glad to know should mine ever Fail. How do you like your 333XL?
        Bugera 333XL 212 Combo 2009 Factory Mod KT-77"'s JJ ECC83S
        Roland Cube 20
        Schecter BlackJack SLS C1 SD Blackouts
        Martin DX1AE Acoustic
        Bad Monkey OD
        Line 6 M9 Stompbox
        Behringer EQ700
        Live Wire Cables
          I know it is a old thread but there are a few heatsinks inside and others report that when it overheats the amp can cut out but then resets itself and when you hit the CLEAN channel it works. If you then try the Crunch or lead channel it will again overheat and reset. Requires some upgraded part and bigger heatsink.
          Roland Cube 20
          Bad Monkey OD
          Line 6 M9 Stompbox
          Behringer EQ700
          Live Wire Cables
