1018 Bar Steel Source? (Thin...like .090" - .1" thick?)
  • 1018 Bar Steel Source? (Thin...like .090" - .1" thick?)
    Might have to have this machined, but I'm looking for 1018 steel bar that is .090" - .1" thick x 2.5" long (height not yet determined).
    Thanks,
    Dave
    That thin it's probably not going to be in flat bar but sheet form
      Good point. That gives me something to look into. Thanks.
        That's an AISI designation, which may give you a dead end if you look for it in sheet stock (I'm not finding anything, some say it's not made into sheet, but I'm not convinced yet). That nominal chemical composition ( 0.15-0.20 C, 0.60-0.90 Mn, balance Fe) is covered by many ASTM and MIL standards, you may have luck looking up the material under that designation. This site lists many of the ASTM specs it's covered under: http://www.suppliersonline.com/propertypages/1018.asp The title will tell you if the spec covers sheet material forms. It will say something like "standard specification for cold rolled sheet" or "standard specification for hot rolled picked and oiled sheet". Material spec land is a vast and deep hole, don't get lost.
        -Mike
          Pretty sure McMaster-Carr has .1" thick sheet....
          http://www.SDpickups.com
          Stephens Design Pickups
            You can buy 3/32"x 1" 1018 in bar stock.
            It is .09375" thick.
            McMaster-Carr
            Good Luck,
            T
              SHeet stock comes in .020" increments so .040, .060, .080" and .100. Someone with a BIG Pexto sheer should be able slice it up in whatever dimensions you need.
                One of the best deals for cutting steel is Micromark's little steel cutting band saw. I've had mine 9 years now and never a problem. It will also cut tile or rock with the added wet cutting attachment and diamond band saw blade. The blades they sell are crap but you can probably have them made for lapidary work. I my steel cutting blades made for me cut to the size for the machine, these are made in Japan and great quality.
                  Where did you hear that? Sheet material is sold by gauge thickness and is dependent on the material. This can be confirmed by other sources, but Wiki is easiest: Sheet metal - Wikipedia, the free encyclopedia
                  -Mike
                    Post Deleted.
                      Don't believe everything you read on Wiki.
                      If there's one thing this forum is famous for, it's people not reading and comprehending the entire post before replying with some snide remark. As a return of the snide favor, please allow me to point this out for you a little more clearer this time:
                      I don't believe everything on Wiki. Oh, and I was working from personal experience too, you're not the only person here who works with metal on a daily basis.
                      -Mike
                        I think I found what I needed at McMaster-Carr. Thanks to all.
