So if anyone has read any of the other threads I've made recently I have a 5150 I've been making some changes to.
Recently I changed the screen grid resistors to 1K and I also connected a small computer fan up to the heater tap on the PT.
Problem is now I turn the amp on and its automatically fully on the standby switch seems to be bypassed somehow? I've checked the switch itself, its fine, I've even disconnected it and the amp still comes on fully. I've double and triple checked everything, measured resistance everywhere on the small PCB board for the power section and I can't see it, I'm thinking its happening somewhere else in the circuit but I just can't figure out where to begin looking or what I could have done while I was making those changes that would do that?
I tried playing the amp and it was ok at lower volumes, but didn't quite sound right and when I switched to the distortion channel or turned up a bit I heard a large snap. took a look and on the PCB where it connects to the tube sockets pin 3 had arced to pin 4.
