Home brew tilt back legs
  • Home brew tilt back legs
    Pretty cool nonetheless
    Came up with an Idea to make some tilt back legs for my Pro Junior since I don't believe Fender makes a Kit small enough for this amp
    had some aluminum plate laying about so decided to use that.
    I'll be able to use the two chassis screws on each side as pivots, just have to drill some holes for the stops
    Rough cuts with Sawzall
    shaped up nicely with angle grinder
    Still need to hit the edges with a file and clean them up
    Haven't decided yet whether to polish or paint black
    That's a good idea. Chrome might reduce chances of tripping vs black. I've dowel around here that could work with just a hole drilled in the back. I've used collapsable Ikea speakers stands too.
    Keep us updated modder!
      got the legs shaped and stops installed. Other that cleaning and polishing, they're done.
      Used a carriage bolt as a stop. the square shoulder does a nice job.
      now time to enjoy the sound aimed at my ears and not my feet
