I was playing my guitar on my amp when someone walked by me tripped on the wire and it fell from the chair. ( I know it shouldn't be on the chair) it fell to the ground while still plugged in. Upon inspection the plug in the back was jammed into the inside. I opened the case and found that where the plug goes into had fallen into the amp itself. How do I fix this thanks!
Fender 15G amp help
Originally posted by Beginner guitarist View PostUpon inspection the plug in the back was jammed into the inside. I opened the case and found that where the plug goes into had fallen into the amp itself. How do I fix this thanks!
What Bill asked.^^^^
SOunds like the rear panel AC inlet. But whatever it is, you will have to open the amp. The connector that was pushed in either stripped its mounting or actually broke, so you probably need a new whatever thing it was. AC cord connectors tend to be universal, so you can find whoichever type is in yours from places like MOuser or Jameco, or even a Fender parts seller.Education is what you're left with after you have forgotten what you have learned.
I would contact Darren Riley & ask if this will work.
Or contact Fender direct & ask for the part number & availability.
Link: http://www.darrenriley.com/shop/cart..._detail&p=2906
