Vibroverb 6G16 tremelo circuit
  • Vibroverb 6G16 tremelo circuit
    So my friend built this amp. We omitted the NORMAL channel from the design and just went with the bright channel since it has an extra gain stage.
    We weren't happy with the stock trem/vibrato circuit. It wasn't intense enough. So, we rewired it to a AB763 Twin Reverb circuit and added the LDR.
    Twin rev schem: http://www.cnjradio.net/fenderamps/t...b763_schem.gif
    6G16 schem: http://elektrotanya.com/PREVIEWS/634...6g16.pdf_1.png
    It doesn't work. I've checked and rechecked the circuit.. many times. I wired it to be ON all the time. There's no footswitch jack. I grounded that point as fixed. I left out the 2.2m resistor that connects that point to the bias supply (twin reverb schem). I figure it's only there to turn the circuit OFF when the footswitch isn't on.
    I added the coupling cap between the last preamp stage's plate and the 1meg series resistor going to the PI. Then connected that junction (per twin schem) to the top of the intensity pot.
    I've checked voltages on the vibrato stages' plates, grids, cathodes, and it's moving all around. I think it is indeed oscillating. However, no audible effect when playing the amp. What I'm not sure of is the coupling cap I added, and the 1meg after the cap. In the Twin this resistor is a 220k not a 1meg. I don't see any reason for this to keep the vibrato from working. I also made the intensity pot 50k, not 250k.
    So, can yall advise me on troubleshooting a vibrato/trem circuit?
    foot in mouth. just fixed it. my friend forgot to remove a wire from the previous circuit. after all my checking/rechecking and almost pulling my hair out I finally posted this for help. ofcourse that's when I figure it out too.
      Hi lowell
      You can just tweak the bias vary trem in the 6G16 circuit to get it slamming good. (for starters remove the plate-to-cathode cap in the LFO, and if you're still not satisfied, decrease the size of the 470k resistor in the depth control voltage divider to around 220k or 180k - so its just on the verge of helicoptering)
        Haha really?? Oh well, I learned a bit about trem circuits in the process. Thanks!
