the Thomas Winder
  • #16
    Originally posted by rjb View Post
    Semantics. To some, "clone" implies "inferior copy".
    Noun: a person or thing regarded as identical to another
    Verb: make an identical copy of.
    No reason to think inferior, and clearly this clone is better. But it's the same basic design, same as a Lakland is a clone of a Fender.
    • #17
      Originally posted by Rob DiStefano View Post
      just finished a winding session using the thomas m2 - a stacked tele bridge, 2 vintage teles for bridge, a trio calibrated strat set and a special way overwound neck strat. i really like this machine. it's very very quiet, easy to listen to radio or hold a normal conversation. also, i'm used to 1300rpm with the sidewinder and this puppy flies at over 1800rpm. pups are now in the vacuum wax bath. life is good, er, dude. sorry. "dude" is typically acceptable veribage around guitar related forums. it's a vernacular salutation that's typically endearing and yes, even hexigenarians use it since for some of us it was a large part of our musical culture from many decades ago. dude!
      That's OK, I was busting your chops! Dude.
      Seriously though, this is a nice looking winder. I was just pointing out that it's the same layout as a Schatten, but better. The better part is important since the Schatten has some short comings, but is otherwise a usable design.
      • #18
        not meaning to beat what is already a rancid and seemingly festering dead horse - ALL "hobby" coil winders are based on the same concept - a motor and a counter. how many different box designs can one invent to stick in those basic components? not many, so let's all get it straight - the thomas, the sidewinder, and whatever home brews are out there are all essentially the same - a motor and a counter. what the box looks like is totally immaterial. what's inside the box is all that matters, and how those components perform.
        so, no - the thomas is not a "clone" of the schatten. that'd be like saying a v/w bug with a porsche engine is the same as a box stock bug. that's it. y'all can now close this thread, it's run its course of usefulness.
        www.frettech.com
        • #19
          Well some home brews are based on lathes. Some other home brews don't have the platens on both sides. I can show you more home brews that don't look like the Schatten than those that do.
          And yes the Thomas is a clone like many guitars are clones of Strats, even if they change the design.
          The fact that Thomas said it was based on the Schatten proves this. You can bold all the words you want and you are still wrong. It's VERY obvious were the inspiration for that winder came from, even down to how its mounted. And that's OK.
          One thing they should have copied is the wire guides being mounted in the center, and not on the ends. That makes it easier to get the bobbin off the winder and not have the wire guide mount in there way, which it is there. I can list a few other things as well.
          And why do you care anyway? That's the part I don't get. Be defensive over something that matters and that belongs to you.
          • #20
            There's also winders made from electric drills. I remember seeing a YT vid of a guy winding on a record player; another where the platen was attached right on the side of a sewing machine. Mine certainly doesn't look anything like the Schatten design (I'm assuming Schatten was the first with this layout) and the way I wind pickups is probably different from someone else because of the idiosyncracies inherent in my winder. The word "design" is worth focusing on rather than "clone". How something is designed makes it different or similar from something else. Over the entire breadth of designs in winders I would say this one and the Schatten are very similar. Are there differences? probably. But looking at all the details of dimensions, layout, use, method of mounting and winding, I would say there are more similarities than differences. If the Schatten hadn't been invented would this winder exist as is? And there's nothing wrong with improving on a design. I don't know what all the fuss is about.
            • #21
              the fuss is about semantics and a person with an attiitude. i'm sorry i started this thread and came back to this forum - it still the same and hasn't changed in years. i'm outta here.
              Rob you are the only person here with an attitude.
              Should I post the rude message you just sent me?
              No one here understands why you have yourself all worked up over this machine. You posted a winder you bought and like. That's cool. That's what this section is for. Now apparently you have something going with the person who built it, which must be why you posted your personal email so people can get info. Thats not so cool. You aren't supposed to use this section to see wares. We have the flea market for that.
              Then you get bent out of shape because I pointed out that it's based on the Schatten, as if that's an awful thing, since you spent part of your first post to bad mouth the Schatten.
              Clearly you have too much invested emotionally in this winder. Buddy, it's a machine. No one is talking about your mother here and no one is saying bad things about this winder.
              Get overt it already. I'm not deleting this thread since people might find the winder info interesting.
              • #22
                I figured the two bars were for winding in the opposite direction
                • #23
                  I don't understand their use. You wind in the opposite direction on the left side of the machine.
                  You only need one bar. Look at the photo of the Schatten above.
                  maybe the machine reverses direction? You still only need one bar. I only use the right side on my machine because the left side of the axle is checked into my drill to power the winder.
                  • #24
                    Dude, it is just is tool, don't get so bent. Holmes was right to call it a Schatten copy, because it is.
                    • #25
                      Some folks need to smoke more pot, some maybe a bit less..?
                      • #26
                        Those 2 arms look like an upgrade in my eyes (I use a Shattern). The bar on the shattern is only held in place right in the center which means you gotta keep an eye on it and keep the one small grub screw on tight otherwise you get a bit of a wobble. Seems that it would be more sturdy on the Thomas, although I can see it getting in the way easily.
                        Someone needs to make a winder with an LED light on a stalk mounted on it so you can backlight the coils when you wind to see what you're doing. Oh and a polarity tester...and a bottle opener!
                        • #27
                          It certainly is an upgrade. The Schatten is a good design, but with some shortcomings due to inadequate hardware. This fixes that.
                          I disagree about the center mounting of the wire guide bar. I like that better, and mine has never come lose. The way they have the bar mounted at the ends will be in your way when you place and remove a bobbin on the winder. You will have to pass in under the bar. So the Schatten method is better.
                          I have a rubber refrigerator magnet stuck to the front of my winder to hold the 2 hex wrenches. So even if the grub screw came lose, it takes a second to tighten it. I've never had to tighten it. You can put some Locktite on it if you want.
                          As far as lighting, I have a desk lamp mounted to my Schatten's base, so I can swivel it over the bobbins when I'm winding. You don't want a back light, you want light from above. That illuminates the wire going to the bobbin. Then I can swivel the lamp over to my soldering area next to the winder.
                          I also have an LED reading light on a stalk to illuminate the counter. So any new winder should have an illuminated counter.
                          • #28
                            I have to remove my long bar once a month or so on the Shattern, the wire wears little marks into the soft metal so I have to polish the bar to remove them otherwise it sticks. I'll try something like Locktite, thanks for the idea.
                            I use one of those twisty LED lights that I screwed onto the back of the winder. Mine is above and behind the coil, you are right David, the light source needs to be above. Hard to rely on natural light with the English summertime I have
                            I noticed that the Thomas winder guy is in the process of uploading some videos of it in action onto youtube. It looks good, however he only ever turns the speed up about halfway so I can't tell how fast the winder actually goes. I'd like to see it in action actually winding so I can see if the load slows the speed down under tension like the Shattern does - Its a well known fact that you can stop the shattern just by holding the wire tightly..
                            • #29
                              They must have changed what the bar is made from. Mine is steel. I have the older machine with the steel enclosure too.
                              My 54 year old eyes need as much light as I can get!
                              Yeah, the Schatten uses a rather small DC motor. I've heard it's a VCR rewind motor.
                              The speed control died in my winder a couple of years ago. I thought it was the motor at the time, and got a replacement from Schatten. The new motor seemed fine, and that started running very slow again like the first one. So it turned out it was the motor speed control that went. Since I had a lot of pickups to wind I needed to get the winder working, so I checked my DeWalt variable speed drill to the left axle. It worked so well that I have been using it that way ever since! It was supposed to be temporary, but since I plan on making a new winder I just left it. It runs MUCH faster, and there's no way to stop it by pinching the wire. I forgot that after I had started using the drill to power it, and went to grab the platen to stop the winder one day like I used to do... man that hurt!
                              Not pretty, but it gets the job done!
                              • #30
                                What if the back light LED could be strobed in time with the winder speed and then slowly rotated to show you exactly how the wire is laying down?
                                Also it's an axle not and axil in English...
