New Compact Winder Being Designed
  • #16
    Originally posted by enkindler View Post
    The controller would be completely different.
    DC is better than a simple shaded poll AC motor but a three phase or BLDC motor allows you to say "accelerate to 5000 RPM in a logarithmic way over 4 seconds" or keep an RPM regardless of load or provide s particular force despite an RPM. They will also take feedback from say, a load cell on a tensioner.
    All of this is via SPI, so the programming difficulty goes way down.
    Brushed DC motors are great for a home built kit but if you are making a new commercial winder for sale it would be best to use modern technology.
    For prototyping RC plane motors are BLDC and actually would be big enough for a pickup winder. I made one heck of a prototype with a 50 oz inch Nema 17 bldc motor but I did not want to spend the time making a frame for it.
    I use a converted mini lathe with a three phase AC motor and a VFD, this is overkill for pickups but with a 1/4 HP three phase motor I get between 2 and 7500 RPM's with acceleration and deceleration ramps.
    I still hand wind but being able to set the deceleration ramp means I can wind at almost full speed until my target wind count and the controller decelerates at the last moment. The ramped acceleration prevents issues when I stop to check the Ohm's when winding by "feel"
    Also these new motor drivers do active deceleration, meaning they turn the motor into a generator and put the output to ground in a controlled fashion. So my emergency stop does full on braking, it is not saw stop fast but it is pretty quick.
    We're open to all kinds of motor options.
    we want this to be inexpensive winder, with a Speed Control knob to turn to make it go faster or slower.
    and, maybe a foot switch, or toggle for instant off.
    On this winder we are shooting for something that is an upgrade to the schatten, sidewinder, and maybe the thomas.
    Something that is affordable to all.
    Then maybe get them to design some auto traverse options later.
    T
    • #17
      T
      An upgrade to the schatten wouldn't be very hard.
      If you price out the components required DC will be just as or more expensive
      Let's consider you use stepper motors, because they are easy to source
      127 oz-in (unipolar)
      The lowest Let's say Nema 24 because the shaft size is nice comparied to 17 and you could direct mount. The 24PK266-02A 127 oz-in (unipolar) motor costs less than $20 in quantity.
      Now for stepper drivers let's pick a fancy one so that you need less MCU, if you go with the top of the top the ST L6470
      The chip is about $10 in small quantities which sounds like a lot however the chip does over current detection, missed step detection, acceleration while also maintaining absolute and relative positions. You will not need a hall sensor to do counting and the number of outside components is very small.
      Add in a simple MCU of your choice (pic, arm32 or heck arduino) that has enough pins for a push rotary encoder and a HD44780 based serial LCD and you are good to go.
      I few more pins for a floor controller or a direction switch would be nice I guess but you wouldn't need anything more than their “value” series” using a higher end motor driver.
      You will need to source a 24v DC power supply or build it into the board but it should all fit in less than 4 square inches of board and cost less than as a high guess $40 in parts in low quantity aka digikey.
      These new smart motor IC's will also step lock, meaning if you had two, one for traverse and one for wrap they would accelerate in sync too. Controlling a DC motor via an H bridge means you will be doing rpm counting externally which means harder integration in the future and/or higher cost.
      I think pickup winders would love saying “wind 9000 winds” and having smooth acceleration and more importantly as this video shows, with the pickup stopping in the orientation you want.
      Here is a video of the stepper driver I am talking about in action, not the accell/decell I would not recommend you select a propeller as a MCU as he has.
      L6470 Microstepper driver - YouTube
      Here is a breakout for that stepper driver, I have no connection to nor do I recommend or have experience with this vendor. I am linking to show you how tiny the passive component count is with this chip.
      https://www.sparkfun.com/products/10859
      I sized this where I think you could get about 800 rpm with 1A out of the chip, which is all that one can support without adding a power stage. Note this winding speed is faster than the But those little steppers should be good for up to 1400 RPM if you could push 3A.
      With the parts any programmer worth his salt should be able to make a simple winder app in just a few days max. Any EE and most hobbyist could design the IC in the same amount of time.
      If you made the physical box nice you would be decades past the "quality gear" that is out there right now.
      P.S. if you made your MCU accept simple gcode commercial winding cam software could be used and you could “duplicate” particular winds even hand scatter ones with ease.
      • #18
        Enkindler..... the winder mentioned in this topic is not going to be any kind of automated CNC type of winder. Just a simple unit for hand winding that's better quality than the schatten.
        • #19
          Stratz,
          A traverse was mentioned above, unless they are talking about cams it will be "CNC" Note that the microcontroller I am talking about costs less than $1 and the machine will have one if it has a counter.
          Even without the schatten has a MCU too for its counter no matter if it was purchased off the shelf or not.
          I am actually talking about reducing the parts count and cost. For a hand winder, the cost of having revolution count stops etc.. would cost less than $10 more in parts compaired to a simple PWM based speed control.
          Personally I couldn't go back to a machine without a tailstock but it would be worse dealing with an inconsistent speed control to reduce cost by a few dollars.
          • #20
            [QUOTE=big_teee;268607]In this Reply I am going to make a numbered list of Items wanted on winder.
            Go over it and reply what you do or don't agree with.
            Then I will send list to Larry at Remington.
            1. Heavy duty Long life motor.
            2. Heavy duty sprocket, belt, and pulley system.
            3. Double ended Ball bearing Mandrel shaft, and with no run-out. (Required for winders that do Top Going only!)
            4. Mandrel needs to be 6-9 inches above table height.
            5. Double Height adjustable Stop Bars, with adjustable stop collars.
            6. If Financially feasible, round tooling plates instead of rectangular, and ideally there would be a way to make them replaceable and interchangeable.
            7. Foot switch, and foot switch jack.
            8. heavy Duty Speed Control, with speed knob located in a forward location???
            9. Winding speed 0-1500 rpm.
            10. A backlit large display 5 digit counter.
            11. Optical Sensor type speed control.
            12
            For right now, If we can concentrate on the basic winder.
            If you can read through the items above, and answer the questions I don't have answers too, that would be a great help.
            I don't have a winder of this type.
            So those of you that have built a sewing machine motor type winder, are more qualified to answer them than me.
            Thanks for the help!
            T
            • #21
              Here's the faceplate on one of my winders ,with similar bobbin mounting holes as Sonny's
              Center hole is for fender style pickups & the others are humbucker bobbin spacings 49.2mm,50mm,53mm all holes tapped with 4-40 screws
              this one was made by Bruce Johnson ,He's a member of this forum & he does outstanding work
              • #22
                I'd like to see a tail stock on the winder. That helps keep certain kinds of bobbins in place.
                • #23
                  T
                  I will take a stab at the speed limitations. I am sure everyone has their preference here. My winder goes from 0rpm to about 2200. I very seldom wind over about 1500 - 1700 though, and usually the control is set at about 1000- 1100 for the max. I am using the sewing machine type rheostat pedal in combination with a common hardware store router speed controller. That works very nicely since I have some additional speed control as well with the foot pedal. The router speed control sets the max speed and I can vary it from zero up to that amount with the foot pedal.
                  I quit using the stop bars so I don't have a good input on that. When I did use them mine were height adjustable anyway.
                  I'd still like to see that light at least as an option.
                  The tailstock as David mentioned would be another nice option.
                  www.sonnywalton.com
                  How many guitars do you need? Just one more.
                  • #24
                    Latest list!
                    Don't know how you would incorporate a tail stock into a small winder foot print?
                    • #25
                      Do you mean having a shaft on each side? I never ever use the one on the left. I reverse the rotation of the motor and wind top coming. Or, flop the bobbin over and wind top going as usual. It's far easier than setting up to wind on the left side of the machine.
                      • #26
                        It would still be an option, for those that want to wind on the other side.
                        I am going to include it on the list I submit.
                        Other than that do you have any height, speed, or other requirements, you would like me to submit?
                        Is the 0-1500 rpm sound about right?
                        I don't wind very fast and that would more than take care of my requirements.
                        T
                        • #27
                          With the double end mandrel
                          I would have mine set up Single coils on one side & humbuckers on the other
                          • #28
                            Exactly!
                            I wouldn't buy a winder without TG option on both sides.
                            • #29
                              I'm interesing, it will be selling on other countries? For example, in Russia? If so, it would be nice to provide an opportunity to use the voltage to 220 volts.
                              Yet it would be nice to be able to freely set the value on the counter, choose the direction of the account.
                              www.fokinpickups.ru
                              www.fokinpickups.com
                              • #30
                                That would be assuming the motor ran in both directions.
