Results 1 to 27 of 27
Thread: Behringer DDX3216 LCD replacement Display
    Junior Member
    Jul 2012
    10
    Hello guys!
    I am looking for an LCD Display Replacement for my Behringer DDX3216 digital mixer.
    In fact I need 3 units because all my 3 boards have defective LCD displays. The display just gradually faded out.....gone.
    Can this still be repaired?
    Hope somebody can help out. I tried to order from the dealer but to no avail.
    Thanks!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,644
    Received: 573/1
    Lost contrast over time? Or the backlight went away? I don't know your experience level, so forgive me, but have you adjusted the contrast or "viewing angle" adjustment?
    Junior Member
    Jul 2012
    10
    Ddx3216 lcd
    Yup done that already and tried also to find out why it is doing that. Tried also to switch the lcd of my old Behringer Digital EQ because the size is the same but the pins/connectors and configurations are not the same. Thought we can use it to replace the mixer's lcd. So next thing to do is to replace the lcd with new ones. Unless there is something we can do to make it work again.
    I guess the problem is in the contrast circuit of the lcd display. But the one that runs the thing are small ICs that are maybe non serviceable.
    Many thanks Enzo!
    Junior Member
    Jul 2012
    10
    I also faced same problem. I also purchased Behringer DDX3216.After few months LCD Display give faulty display. I mean it has missing few vertical rows of dots .
    Junior Member
    Jul 2012
    10
    ddx3216 lcd problem
    Quote Originally Posted by warunasanjaya55 View Post
    I think that might be an easier problem if you do component level repair. Loose connection in the LCD rubber connector may be doing that. Not really an easy thing to do and you have to be very careful in removing the lcd panel and the circuit board that connects to it. But hopefully that is the only problem. Unlike mine. 3 Boards of the same problem. Everything faded out slowly until nothing but just a backlight can be seen. This is why I need new sets of panels.
    New Member
    Oct 2012
    1
    Quote Originally Posted by efxmla View Post
    I am also facing the same problem of gradually fading screen.
    The lcd screen on my DDX3216 has gradually faded to a point that it takes almost 2+ hours for it to "warm up" and all i can see is a faint image on the screen. I literally have to plant my eyeball 2 cm from the screen to see anything!
    The backlight is still lit.
    While mucking around with the internal connection, I can force the LCD panel to show a all black screen by improperly connecting the connector, so it MIGHT not be the LCD fault.
    Any kind soul here have and opinions on the matter?
    Desperately need help coz there is no one else around in my country that I know of that will fix the mixer and I am left to my own devices now.
    Many many thanks in advance!
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 10/0
    These LCD panels often need a negative contrast voltage to work. The viewing angle knob adjusts the voltage.
    If the contrast voltage is too low, you get the symptoms described, a very faint image or none at all. Too high, the display goes completely black. Also the voltage required depends on the temperature of the goop inside the LCD panel, so that agrees with the observation that it "warms up".
    Unfortunately I have no idea of what specific circuit was used for contrast voltage generation on the Behringer panel. Indeed sometimes the circuit isn't on the panel but on the motherboard. It could be a little switchmode converter, or a charge pump, or just hooked up to the analog -15V rail.
    This application note may help. http://www.hantronix.com/files/down/neg-invr.pdf
    Some of the better circuits include a thermistor to temperature-compensate the contrast voltage. Maybe the thermistor could be bad. Just thinking out loud now.
    Old Timer
    Apr 2008
    Oceanside, NY
    1,649
    Received: 1/0
    I rarely get involved in discussions about the DDX3216, because, quite frankly, they were born bad. Lots of issues, right out of the box. Even more down the line. A bear to work on, even WITH documentation, and few parts available. They are all doorstops if they don't work.
    As far as the LCD display goes, we ordered 6pcs. for stock in 2004. Never received them, and the part is no longer available. I CAN tell you that the display was made by Epson, so perhaps you can use that info to track them down.
    John R. Frondelli
    "Mediocre is the new 'Good' "
    Aug 2012
    UK
    60
    Quote Originally Posted by jrfrond View Post
    Well yes they did have issues.......still using 3 here ...with NO issues,and those that had issues ,were resolved.
    The audio sections have been modded and all Digital glitches removed
    Just depends on how far your understanding of the beast goes,
    Repaired about 10 so far with total success,
    Most are caused by user ignorance and abuse, and exposure to high moisture levels !,
    PSU issues are the bain of many problems associated with the desk ,recapping is essential, and then setting up the voltage presets/current draw is paramount to trouble free operation.
    All the parts,chips etc required to repair are available,...except the hex code for 2 of the PIC Chips,which of course are protected !(CPU board [smpte]and ADAT card io)
    So I will take you statement with a pinch of whatever.
    As for the LCD failures, the element conductive pads get stressed and do not conduct,dissasemble clean ,reassemble, replace caps and reflow all the tosh chips, 99% success.
    Cheers !
    Junior Member
    Sep 2013
    12
    Hi I am new here and have got this DDX3216 from a friend who said it was working perfectly and had shipped it to me.
    When I unpacked and powered it up, everything came on except the LCD which only lights up abt half and is completly black.
    Have been trying to fix the issue but I am not very experienced with LCD's
    Is it a fault of the LCD or any other IC, PSU related issue?
    Any help would be highly appreciated.
    New Member
    Dec 2013
    2
    Behringer DDX3216 LCD available in pack of 10 mail me at jd130208@gmail.com for details
  12. #12
    New Member
    Jan 2014
    6
    I have the same problem with the display fading out slowly, I checked the the resistors on the back of the lcd board and found R8 bad suppose to be 127K and reads 453K and R7 which is in series with R8 is a 22K resistor and it is ok, I have ordered the parts and will replace and let everyone know if that fixes it. I also have a bad ANAout01 board which has 2 of the 846 transistors bad and 2 of the 60 ohm resistors and a couple of the 4580L IC chips that are bad. All of the parts are very cheap to replace.. hope this will be of some help for the people with the LCD display problems.
  13. #13
    Feb 2010
    10,192
    Received: 333/1
    Given: 661/0
    Testing 846 transistors gives me very sad face .
    Edit: maybe that's a part number, not 8 hundred forty six separate transistors .
  14. #14
    New Member
    Jan 2014
    6
    Quote Originally Posted by g-one View Post
    yes it is a part #BC846BMTF NPN transistor ,sorry about that, I am so used to being a electronics repair man, I think i am talking to people with a electronics background.
    g-one, I hope i have cleaned up my own manure.. and the ANAOUT01 Board has nothing to do with the LCD display, it is just another problem if you have no audio out put at the speaker output jacks or the left or right channel is not working. forgive me. and if you have any problems you can email me at bwilds5044@yahoo.com
    Last edited by bwilds; 02-08-2014 at 04:37 AM. Reason: just thought of something that he said
  15. #15
    New Member
    Jan 2014
    6
    Hello guys!
    Thanks!
    This might be worth checking, on the LCD display board, check the (5) 4.7uf 16 volt capacitors that are tied to the IC1 LM324 quad opamp chip.. they are suppose to be 35 volt capacitors instead of 16 volt ..
    they are bad on my board, i checked them with the sencore cap tester and they are showing 000 capacitance and no ESR reading
  16. #16
    New Member
    Jan 2014
    6
    check C-1 C-2 C-6 C-7 C-8 and see if they are 16 volt caps they are suppose to be 35 volt caps, mine were 16 volt, then check the other 5 caps, half of mine were bad,replaced all the caps on mine.
  17. #17
    New Member
    Jun 2015
    1
    Update Plz?
    Quote Originally Posted by bwilds View Post
    I have the same display problem with my DDX3216...Display starts up for a second, then drops to a barely viewable screen....
    Just wondering if your fix worked...
    Thanks for any help!
  18. #18
    Junior Member
    Jul 2012
    10
    Many Thanks! I hope and I'm sure this will help a lot! Would you have a complete schematic of the LCD portion? Mine has an incomplete diagram so I can't establish the missing ones. Thanks again!
  19. #19
    New Member
    Aug 2015
    1
    Hey all,
    I'm having the same problem. The LCD barely shows anything. I can get it to show a complete black screen with proper contrast and everything, but when connected properly it barely shows anything.
    Replaced all of the capacitors on the LCD board, but that didn't help
    I found this page: PLZILandia v5.0 - DDX3216 but suprise, suprise, the one PDF that I need is the one that is incomplete on it...does anyone by chance have a complete version of it?
    Any suggestions as to what I can do with this? I really wanna fix this and use it!
    Thanks in advance!
  20. #20
    Junior Member
    Jul 2012
    10
    I think that is a common problem with the schematic. A portion is missing. All capacitors and resistors have been replaced but to no avail. I am now trying to convert to another screen. If I will be successful, I will let you know because I have 3 units of the same problem. Meanwhile, we will keep on trying!
  21. #21
    New Member
    Dec 2016
    1
    Hi All. I have the same problem with the DDX3216 screen. It lights up, but cant see anything on it. I don't know enough about electronics to attempt a repair, so, could someone recommend an engineer to repair it please, preferably in Essex, UK. Thanks.
  22. #22
    New Member
    Jan 2018
    3
    ddx3216 / display
    easy fix. take out the display board, locate SCI7654 voltage converter and replace ALL caps near it.
    caution: use 10 / 25 V type as specified.
  23. #23
    New Member
    Mar 2018
    3
    Is this the issue experienced (or similar)?
    https://www.youtube.com/watch?v=48NUk1Lw2sI
  24. #24
    New Member
    Jan 2018
    3
    sorry to disappoint, I experienced exactly the contrary, display fading out until unrecognizable. however, check this inverter stage. I am tempted to see a thermal problem, since in the video the display works for at least a few seconds.
  25. #25
    New Member
    Mar 2018
    3
    Something like this
  26. #26
    New Member
    Jan 2018
    3
    that looks as if the display itself would have a problem with the ribbon connectors. you will need to open the lcd shell and check the contacts and if necessary clean them. tricky job, though.
  27. #27
    New Member
    Mar 2018
    3
    @mike777 - thanks. Will give it a go because the desk means nothing at this stage. Any pointers?
  1. Behringer DDX3216 - Trying to repair, please help!
    By fznuk in forum Music Electronics
    Last Post: 09-09-2018, 01:32 PM
  2. behringer ddx3216 problem help needed
    By flashpump in forum Music Electronics
    Last Post: 02-14-2016, 09:33 PM
  3. Johnson Amplification JM150 LCD display repair...
    By pecorporation in forum Music Electronics
    Last Post: 06-22-2015, 05:57 PM
  4. Behringer DDX3216 problems
    By choe62 in forum Music Electronics
    Last Post: 02-28-2015, 09:19 PM
  5. Kurzweil PC2X LCD Screen Replacement
    By oc disorder in forum Music Electronics
    Last Post: 02-07-2011, 12:18 PM
