Advanced switching
  • Advanced switching
    Hi,
    I have 2 amps that I want to switch (normal A/B) + at the same time I need to switch their send loops into one.
    Amp one is an old MS that I use together with a load box (as a giant preamp if you like). The load box provides an output line signal that I wanna connect to some kind of switch, Also connected to the same switch is the send signal from the effect loop of amp two, a Peavey 5150. Now the output of the switch is connected to the return loop of the 5150. So I'm basically using the 5150 as a power amp for the MS and of course normally as the power amp for the 5150 preamp.
    I want in a single press switch the input of the amps AND the send signals. Is that possible with any commercial product on the market?
    BR,
    Peer
    Check out the Lehle stuff. It's not cheap.... they use high-end transformers for wide frequency response.
    Now Trending: China has found a way to turn stupidity into money!
