Bose PAS PS1 power supply schematic or info needed
  • Bose PAS PS1 power supply schematic or info needed
    two terminal device immediately following toroid coil in Bose PS1 power supply has exploded. Looks like it may have been a thermistor to control inrush current. no markings visible. Any input would be appreciated. thank you. LTEC
    You are probably right, if it is in series with the mains. Do you have ANY inrush thermistors for other equipment? Some fender amp or maybe another SMPS?
      Hi Enzo. Thanks for the quick response. I have in fact found some info. The device was an NTC SCK 2R515 capable of handling 35 amps. The Kind folks (even on saturday) at Digi Key helped me cross reference part numbers and order a replacement--actually a couple, in case their is a dead short somewhere downstream. Its not easy to get tech info for Bose. I think I'm in good shape now, Thanks (unless someone actually has a source for a schematic).
