... Preferably undrilled??
Plastic mini-bucker covers...
Originally posted by LtKojak View PostIf the soldered cover is the only thing holding a mini-hum together, I don't think you're gonna find PLASTIC covers for'em.
HTH,
Soldering stuff to the cover isn't part of the plan.
HTH,
I don't see any looking through the various covers from Daeil. G&B's website seem to be gone.
You can do it like the way Bartolini used to do it, by vacuuforming. I think that's how Spence is doing it, and his covers looked real nice.
A 3D printer will work, but the surface needs a little cleaning up, at least on the ones I had made.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
For a while there was both buttons.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostFor a while there was both buttons.
It was too much trouble, because he had to do it each time he updated the server.
So he let the thanks go!
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
If you need to buff a soft plastic, toothpaste works pretty well.
It's abrasiveness is well-controlled by regulatory organizations."Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
Originally posted by salvarsan View PostIf you need to buff a soft plastic, toothpaste works pretty well.
It's abrasiveness is well-controlled by regulatory organizations.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
