Results 1 to 10 of 10
Thread: Motorboating in my 5e3
  1. #1
    Junior Member
    Join Date
    Apr 2012
    Posts
    8
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Rep Power
    0
    Question Motorboating in my 5e3
    Hiya,
    My weber 5e3 clone which I have had working (on and off) since 2009 has now started motorboating when the volume controls are high. All the controls effect the speed/volume of the motorboating.
    There is also wicked hum in the normal channel.
    I've changed out all the tubes, which has had no effect on the problem.
    Where do i start?
    Thanks in advance
    0 Not allowed! Not allowed!
  2. #2
    Join Date
    Feb 2009
    Location
    Canada
    Posts
    125
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    12
    When in doubt ask R.G.
    Motorboating
    Excessive Hum
    Looks like you need new power supply caps.
  3. #3
    Supporting Member loudthud's Avatar
    Join Date
    May 2006
    Location
    Near Dallas Texas
    Posts
    3,575
    Thumbs Up/Down
    Received: 266/0
    Given: 132/1
    Rep Power
    19
    Check / clean / re-tighten the input jacks and pot nuts. Also, any transformer bolts used for ground lugs.
    1 Not allowed! Not allowed!
  4. #4
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,432
    Thumbs Up/Down
    Received: 3,068/5
    Given: 3,708/0
    Rep Power
    32
    +1 to both.
    Power supply caps SHOULD still be good since they're only three years old. But that's no guarantee that they are. A bad ground, most likely in the power supply, is always a good suspect with your symptoms.
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
  5. #5
    Junior Member
    Join Date
    Apr 2012
    Posts
    8
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Rep Power
    0
    Cool thanks guys. I will take out the chassis, tighen everything, and reflow the solder in all of the preamp section and the power filtering section.
    I should mention that in January I completely gutted the amp, and replaced the eyelet board with a fibreglass turret board and replaced all the discrete components (big electrolytics, resistors, everything).
    So I don't think any individual component should have failed from old age (but who knows!).
    I'll report back after the basic reflow and tightening. Thanks again
  6. #6
    Junior Member
    Join Date
    Apr 2012
    Posts
    8
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Rep Power
    0
    Ok, so i have tightened all the bolts, pots and jacks. none of them were loose.
    I've reflowed the solder on all the joints on the board. I'm still getting the motorboating a certain settings.
    What should I look for next?
    Thanks!
  7. #7
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,432
    Thumbs Up/Down
    Received: 3,068/5
    Given: 3,708/0
    Rep Power
    32
    Have you tested all the grounds? Especially the filter cap grounds. Also test that all the filter cap + leads have a zero resistance path to their respective plate loads. If all checks out get a 22uf/450V cap and solder an aligator clip (the kind with rubber insulation) to each terminal. Then clip it across each filter cap one at a time testing for the problem. Remember that the cap will be charged after it's clipped into the circuit, so don't shock yourself. If clipping the cap across any of the existing filters stops the problem, replace that filter cap.
  8. #8
    Junior Member
    Join Date
    Apr 2012
    Posts
    8
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Rep Power
    0
    Will do. Thanks!
  9. #9
    New Member
    Join Date
    Jul 2018
    Posts
    1
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Rep Power
    0
    Quote Originally Posted by Chuck H View Post
    Thanks for the info, this helped me! I found the issue with the motorboating in my 5E3 by using this method of alligator clipping a 22uf cap across the existing caps.
  10. #10
    Junior Member
    Join Date
    Apr 2012
    Posts
    8
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Rep Power
    0
    Hey thats great! I can’t remember what I did. I may have taken it to a real tech. But I have had a lot of the big spragues go bad and I dont use them anymore.
Thread Information
Users Browsing this Thread
  1. 5e3 motorboating?
    By chuckb in forum Debugging Your Build
    Last Post: 04-04-2011, 03:00 AM
  2. Motorboating issue
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-08-2010, 08:59 AM
  3. Troubleshooting motorboating
    Last Post: 04-23-2008, 10:17 PM
  4. Do I have classic motorboating??
    By casey73 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-24-2007, 05:07 PM
  5. Reverb motorboating
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-26-2007, 06:33 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
