Does anyone recognize the type of tubes the two to the right of the 6V6 in these pics are? 8-pin, no markings on the glass.
Tube ID help
Look like twin triodes, my guess is the one on the right might be a 6SL7 and the center one maybe a 6SN7.
You can see inside the tube, you can probably see where each internal element is connected to the base. LOok up the tubes I mention in a data sheet, and see if the plate grid and cathode connections show the same pattern.Education is what you're left with after you have forgotten what you have learned.
Also, WRT older tubes, there is almost always a certain marking that remains even after the marketing print is long gone. It may be nearly invisible unless you hold it just right in the light. Usually surrounded by an elongated octagon, like a rectangle with the corners cut off and a tube designation number inside."Take two placebos, works twice as well." Enzo
And while we are used to the number being on the side of the tube, back then, a lot of them had the type number on the top of the glass.Education is what you're left with after you have forgotten what you have learned.
Same pinout. Would probably "work" in each others sockets. Different voltage ratings and amplification factors. So... Not really interchangeable as direct replacements for one another. No more than the typical 12XX7 tubes that people are fond of subbing for each other."Take two placebos, works twice as well." Enzo
Or... A 12au7 and a 12at7."Take two placebos, works twice as well." Enzo
