I purchased (for probably too much) a Guyatone Bass Man amp that looks and sounds fenderish with a very similiar component layout. There are a few differences from a fender bassman but it is two channels with master volume and no effects with a 4 6l6 tube compliment. Now my only concern is that the output impedence isn't marked anywhere and I don't know what it should be. I have been running it through an 8 ohm cabinet with no apparent problems but I like to have some comfirmation before I run it like that for too long. Has anybody had one of these and knows what the impedance would be. I know I can figure it out by running a signal through the output transformer but if someone knows it would save me some time. Thanks in advance, Doc LowLow.
Guyatone Bass Man ??? output impedance
Guyatone bass man output impedance
hello,
i've gathered some information about Guyatone GA-1100 amps (Reverb Custom, Reverb Rock, Bass Man, ...?) on a homepage:
According to the schematics of a Guyatone GA-1100 S these amps should have an output of 4 Ohms.
greetings,
sonni
