SE amp for 2 miniature triode/pentodes
  • SE amp for 2 miniature triode/pentodes
    Got a few spare parts lying around, including an ECF80 and an ECL80
    By my calcs the junkpile 15k OT I have in mind ought to be 'sufficient' for either pentode.
    So which pentode would people here go with as the audio output? The ECL80.pdf or the ECF80.pdf?
    The triodes in both types of tube a close-ish to a 12AU7 AFAICT.
    (My idea consists of having a pentode input dc-coupled to a CF driving a tone stack/control and vol, followed by a triode recovery stage for the NFB insertion point and the output pentode.)
    "L" designates a power pentode and "F" is a small-signal one. I'd use them for what they were designed for.
      TFT Steve
      FWIW i just stumbled across this cool article on the National Valve Museum site
      Valves and their Habits
        Gonna be noisy with the Pentode in the front end but if you scale it way down and cut some of the gain you may get it quiet enough. You'll get a nice big tone from the Pentode but like I said go to the well to quiet it down.
        KB
          I have wanted to make a small spud amp for a long time to use this 6em7 I have. The triode/Pentode tubes like you have seem even cooler for a guitar amp tho. I have a small little chassis that would be perfect, it isn't much bigger than a pedal.
          edit:
          here is a tube I stumbled upon, the PCL805 it is a t/P and it looks like it might have some guitar amp potential with 10.5w max plate dis on the pentode.
          http://www.mif.pg.gda.pl/homepages/f...4/p/PCL805.pdf
          http://www.ebay.com/itm/1x-PCL805-NO...item3cb3587ab8
            Found on AX84 - Box O' Dirt => Box O Dirt pictures by tkdrew - Photobucket
            Where do you guys get these "junkpile" transformers from?!
            Jaz
              Junkpiles
