Results 1 to 7 of 7
Thread: The carlsbro 100 pa/r amplifier
    Sep 2012
    South coast UK
    664
    Received: 27/0
    Given: 40/0
    8
    Red face The carlsbro 100 pa/r amplifier
    Hi
    This is my first post.. I'm new to the land of valves really. Ive got a Calrsbro 100 watt Valve PA Head which i use for bass in a 60s/70s band in UK.. Its got a set of quad JJ's EL34s. Is there any tweek i can do to make it better for the bass. I aint touched the biasing ..It seems to be over driven, possibly without being that loud. As i only play with drums and guitar...I use Fender P Bass with Bareknuckle pickups and the amp goes though a warwick 2 x10" Looking on line today saw videos about changing caps/ resistors in tone stages. any help with biasing too would help... I only have a Multi meter.. I dont have an Silly scope or signal gen's
    can anyone help ?
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    3,142
    Received: 383/1
    Given: 44/1
    16
    Assuming that this PA amp is working correctly, (Easy enough, run a mic into an input and see if it is clean and loud) I would just get one of those $25 Art tube preamps and run it into a line level in jack or main amp in. The Art preamp even has a voicing switch with a bass selection. This way you don't need to modify anything or waste any time at all.
    Sep 2012
    South coast UK
    664
    Received: 27/0
    Given: 40/0
    8
    Hi.. Many thanks the amp is working fine. I will look into that Art tube John
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 15/0
    23
    Back in those days, PA amps, bass amps and guitar amps were all kind of similar. If the power tubes haven't been replaced in many years, they may be worn out and a new set could make it louder and cleaner. Failing that add more/bigger speakers.
    The schematic:
    Carlsbro 100 PA/R Amp Schematic
    Sep 2012
    South coast UK
    664
    Received: 27/0
    Given: 40/0
    8
    Hi many thanks i dont want more speakers as i live in 2 nd floor flat.. I have replaced valves new set of JJ's.. will have a go at Biasing i will changed the caps anyway i think.. thanks for the schematic .. i already downloaded it from champ
    Dec 2007
    3,142
    Received: 383/1
    Given: 44/1
    16
    Here's a link for the Art preamp. They make several variations. I have one that has a selector switch for a bunch of different voicings including bass for the same price:
    http://www.musiciansfriend.com/pro-a...dio-mic-preamp
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,044
    Received: 2,852/4
    Given: 3,344/0
    31
    I don't think a preamp that's more refined is a bad idea at all. But I don't see how it's going to make the amp louder. The OP should add a 15" speaker to the pair of 10"s he's using now. No rules about when he needs to use all the speakers. That is, only use the big guns at practice and gigs.
    On the note about adding speakers. It's possible that the load your 2x10 cab presents is less than ideal for the amp. A good impedance match is important for max power. After that I'll +1 on needing good tubes. A proper bias and good filter caps are also paramount to achieving max power.
    There are some minor changes that might be made too. But it won't amount to a hill of beans compared to what's already been covered. Different film cap, types or values and different resistor types or values absolutely will NOT make the amp louder.
    If the amp is tube rectified AND the other components in the amp are up the it you may be able to change to a diode rectifier. This could allow more filtering (better for bass) and an increase in voltage (tighter bass, more power).
    On the note about NOT wanting to add more speakers... If the amp gets louder because of more speakers OR because of circuit changes, what's the difference??? The amp will still need to be turned down more to practice at home, right?
  1. Replies: 1
    Last Post: 06-25-2016, 10:58 PM
  2. Portable PA Peavey versus carlsbro
    By ASPD01 in forum Other Amps
    Last Post: 01-01-2013, 10:46 PM
  3. 2 carlsbro 100 tops, with different problems
    By per111 in forum Vintage Amps
    Last Post: 07-05-2012, 04:46 PM
  4. Reducing noise in Carlsbro valve PA head
    By Martin Beer in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-08-2011, 09:01 AM
  5. CARLSBRO GRX7 MIXER PA AMP INTERNAL FUSE BLOWS Help Please
    By sim in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-27-2010, 03:04 PM
Tags for this Thread
