Results 1 to 5 of 5
Thread: Peavey 8 Pin MIDI
    May 2010
    Sioux Falls, SD
    5,780
    Received: 768/1
    Given: 626/1
    14
    Peavey 8 Pin MIDI
    I'm looking for a schematic/pinout for the 8 pin MIDI input for a Peavey Tubefex. Iv'e got to build some special/custom cables/adapters for a MIDI merge circuit and I need to know what pins are MIDI, what pins are power, how much B+, etc.
    Thanks In Advance
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,478
    Received: 1,381/7
    53
    COntact customer service at Peavey and ask for the schematics for your unit.
    I could be wrong, but I;d be very surpriseed if they were running B+ down a DIN cable.
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    22
    I believe the data pins are the same as a regular 5-pin MIDI cable, so the socket is compatible with other MIDI cables and devices. That's all I know unfortunately. The power is probably 5 or 12V.
    May 2010
    Sioux Falls, SD
    5,780
    Received: 768/1
    Given: 626/1
    14
    Got the schematic from Peavey. FYI they do run power via the DIN cable. It was quite the little project. The band plays to a sequencer and the guitar player wanted to be able to switch patches via the footpedal and/or via MIDI out of the sequencer. So the chain is sequencer and pedal into a MIDI merge box. MIDI merge box out to the Tubefex. The problem is that the pedal gets its power from the tube fex via an 8 pin DIN and there is also a MIDI return so that if you switch patches directly with the buttons on the Tubefex it updates the pedal. (I know....confusing).
    Anyway, what I had to do was carry pedal power, MIDI return, and ground straight through from pedal to Tubefex and split MIDI and ground out of the cable to route through the merge box. The pain was all the switching from 8 pin to 5 pin to female to male, etc.
    The customer tried it out last weekend and said it worked like a charm. In fact, he had me build another one for the other guitar player in the band.
    31,478
    Received: 1,381/7
    53
    AH. Just a note: we generally reserve the term B+ for the plate supply of tube circuits - several hundred volts.
  1. Peavey Classic 50 Sparking Tube Pin
    By speedcity89 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-12-2010, 09:18 PM
  2. Peavey 6 pin din replacement help
    By Angry_ninja in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-17-2010, 02:35 AM
  3. Analog to midi
    By intarsiaq4 in forum Music Electronics
    Last Post: 01-27-2010, 06:09 AM
  4. 7 pin midi
    By tsmilliner in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-02-2009, 10:24 PM
  5. midi questions
    By Marina in forum Music Electronics
    Last Post: 12-26-2008, 03:16 AM
