converting old pa amp for harp amp
  • converting old pa amp for harp amp
    can anyone tell me how a amp with 4 ,6AB4,s and 2, 12AX7,s will work for a guitar/harp amp this amp has 4 mic outputs or inputs what ever you call them
    The 6AB4 & the 12AX7 are both triodes.
    They are generally used as preamp tubes.
    Not that they cannot be setup as output tubes
    It won't be very loud, that's for sure.
      well maybe I should pass that one by?the amp has 7 tubes but I can only read 6 of them 4 are the 6AB4,s 2 are the 12AX7,s it was a innercom system I think it has tone and volume controls I just don,t know yea I just found out that the 7th tube is a 12AX7 as well
