Does anyone havea clue as to why the 3 indents are seen on some t tops? i have a pair like this and they look melted with the indents and i have no clue if its manufacturing. any ideas?
3 indents in patent number pickups
they are simply sprues where the plastic was injected into the mold, the ones that sink are simply from cooling of the part....http://www.SDpickups.com
Stephens Design Pickups
It was never intended for you to see the bobbins since the pickups had covers, so they didn't really care what they looked like.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
For your obscure technical knowledge file: The little circles that you see on the surface are caused by the ejector pins. The mold is made with a group of holes and sliding pins that are operated by a pneumatic cylinder. During the molding cycle, the tips of the pins are flush with the inside surface of the mold. When the plastic is cooled, the mold opens, and the cylinder pushes the pins, which ejects the part from the mold. The little circles are the result of the small amount of clearance needed between the pins and the holes that they slide in. The injection pressure causes a little ring of plastic to seep into that clearance. As the mold wears from thousands or millions of cycles, the pins get sloppy in the holes and the circles of plastic stick out more.
David's right, the depressions are caused by some misadjustment of the temperature/pressure/cooling cycle. If it's out of adjustment, some areas of the part will cool too quickly, causing the depressions. Injection molding is a fussy process.
Originally posted by Jim Shine View PostIf you get some of the NOS clear ones floating around, every one that I have had so far has a little air bubble trapped underneath each of those depressions.
www.sonnywalton.com
How many guitars do you need? Just one more.
Originally posted by SonnyW View PostI have a few of those, the Gibson NOS Clear T-Top ones, that surfaced a few years ago.
Vintage Gibson Parts Clear Pickup BOBBINS T Tops 8 Pcs | eBayIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
