SS Ampeg B100 power transistors - What are they?
  • SS Ampeg B100 power transistors - What are they?
    I'm repairing a solid state Ampeg B100 amplifier and one of the output transistors is shorted between the collector and emitter. The numbers on the T03 part is 7648 and the schematic is a homebrew ampeg part number. Does anybody know of a power transistor that I can use?
    That's most likely a manufacturor # but if it's the NPN the MJ-15025 should work and a PNP would be it's compliment MJ-15024. Make sure the emitter resistors aren't open on that blown network and the drivers for that matter.
    KB
      Just a thought, but if you actually include the made up part number, it will be a whole lot easier to look up. 7648 looks like a 1976 date code.
      You got those backwards, KB 15024 is NPN. Also MJ15003 are common and would also work.
      At this point I would HIGHLY recommend replacing ALL of the outputs, so they will match. i wouldn't count on a modern transistor sharing current well with the old ones.
        At this point I would HIGHLY recommend replacing ALL of the outputs, so they will match. i wouldn't count on a madren transistor sharing current well with the old ones.
        Thanks Enzo, I crossed it to NTE and wrote it down as 388 instead of 68 which is it's compliment. I did exactly like you said in a DCM 600 just changing the bad one and it didn't like just one transistor and two fried so that is a great tip.
        KB
          In my unit were a TIP35A and TIP36A
