Results 1 to 8 of 8
Thread: Fender blues DEVILLE repair. Blown R3000 diodes + Insane noise
    New Member
    Dec 2012
    2
    First of all a big hello to the musicians and amplifier techs here!
    I repair amplifiers part time at home, i mainly want to continue making guitar pedals but Reputation gets around and amp repairs help fill my gas tank. (Vertical Amplifiers is my company name)
    A friends Fender DeVille would work and play fine, and then after a few minutes the speakers would go into shock with LOUD buzz.
    Replaced the blown R3000 diodes(D5-D4) with 3-1000v rated diodes in series for each side.
    Now the buzz is instant as soon as standby is switched on. I was thinking the Output Transformer is shorting (because what had blown D5-D4 may also have damaged the OT) but both Blue and Brown measured 50ohms and 54.5ohms to the Red centertap. Are those normal resistance on the primary coils?
    I will check the Phase Inverter plate voltages tomorrow and R57. Also those solder joints like Enzo+52Bill had suggested in previous posts.
    Im working 12hrs a night right now (8pm-8am) so im having time trouble to find and fix issues and am glad i found this forum.
    BTW- SWR SM900 bass amps are my nitch. Two friends have them and i have fixed many issues and quarks if you are having trouble with them!
    -Will
    New Member
    Dec 2012
    2
    -UPDATE- pin 3+8 Phase Inverter voltages are at zero. However the voltages are on pins 3+8 for 5 seconds when the amp is cold started!
    -UPDATE 2-
    Replaced the tube- BAM problem solved.
    When the PI (a JJ' ECC83S) Heated up to normal temp for some reason current would stop flowing through the cathodes... Just a bad tube. Hope this helps anyone! he said he had just replaced the preamp tubes. I have had 1-2 JJ' brand tubes be DOA right out of the box. But I love there sound, will just have to buy tested ones.
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    Nice fix!
    Which begs the question 'why did the flyback diodes fail?'
    Old Timer
    NYC
    1,654
    Received: 5/0
    Quote Originally Posted by Jazz P Bass View Post
    Nice fix!
    Thats what I'd like to know.A bad PI tube would not cause that.I think that amp will be back soon.
    Sep 2013
    26
    Did you remove the diodes from the circuit to check them? I know this is silly but I thought I'd ask, given that measuring them in circuit would give a zero diode check or other, due to being across the primary.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,651
    Received: 579/1
    The flyback diodes are not across the primary. They are from each end of it to ground. That essentially puts them across the B+ supply.
    If one is shorted, it will reads so and ground the B+ at that point. If the other one is still good, at its cathode we would find the resistance of the primary to ground. Unless your B+ is shorted to ground or your primary is shorted to frame or secondary, ther is nothing to make the diodes appear shorted.
    Sep 2013
    26
    I understand what you are saying... when I looked at the schematic I thought the primary centertap was at ground. Something must have really juiced up those diodes!
    Lifetime Member
    4,271
    Received: 52/0
    Flyback diodes have nearly 2x B+ across them. The on-side output tube pulls down to within 50-75V of ground when it's turned on hard, and the off-side tube plate flies up to B+ plus the voltage across the other side by transformer action.
  1. Fender 212 Deville Running Guitar & Mic (blown resistor)
    By tofearthewolf in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-15-2012, 07:37 PM
  2. Fender DeVille 212 - Distortion Channel Blown Out (checked speakers and tubes)
    By tweety3537 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-25-2011, 04:07 AM
  3. Fender Blues Deville - No Reverb
    By Wildcard in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-20-2011, 12:23 PM
  4. Fender Blues DeVille Faceplate?
    By Mark Black in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-16-2009, 07:41 AM
  5. fender quad reverb blown, repair help.
    By rochotte in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-21-2008, 10:20 AM
Tags for this Thread
