Results 1 to 10 of 10
Thread: Electromuse Model 10 A
    Oct 2012
    88
    7
    I am looking for a schematic for an old electromuse model 10 A amp. I have one I am rebuilding as I replace parts I think I put the tubes back in the wrong places because once I replaced the multi can cap and plugged it in the rectifier tube seemed to be shorting out it had blue flames or shorts going on. I found a few schemo,s that look about the same but they have different tubes so if anyone knows where I can find one or maybe what I did wrong.Any Ideas or help will be appriceated thanks
    Jun 2017
    Ontario, Canada
    326
    Received: 18/0
    Given: 33/0
    2
    Quote Originally Posted by RitzRed View Post
    I could use the schematic for this amp. Did you ever find one? Or what were the similar ones you mentioned?
    May 2010
    Sioux Falls, SD
    5,788
    Received: 772/1
    Given: 634/1
    14
    Jun 2017
    Ontario, Canada
    326
    Received: 18/0
    Given: 33/0
    2
    Thanks!
    Interesting design, I don't think I've seen phase inversion done quite like that like that before.
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    I don't see a working circuit there at all. I mean, it might work, but makes no sense.
    One power tube just has input grounded, so it would act like a single ended amp, I would think. That would be pointless.
    Edit: never mind, had not seen this circuit before, my mistake.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,480
    Received: 1,383/7
    53
    No, the input isn't grounded, the grid is grounded. That leaves the stage cathode driven. The cathode is the input. The signal varying voltage through the cathode of the other side varies the voltage across the cathode resistor, which in turn varies the voltage at the cathode of the mystery side. That works against the grounded grid to put signal through the tube. Think Music Man.
    1 Not allowed! Not allowed!
    Cheshire, UK
    2,023
    Received: 326/4
    Given: 198/0
    15
    It's not single ended. It's a "self split" push pull output stage. One grid is grounded and the common cathode resistor isn't bypassed making it work like a long tail pair PI
    Oct 2015
    Brisbane, Australia
    24
    Received: 1/0
    0
    Absolutely...! Think old Magnatone amps (Model 109 if my memory serves me). In the Magnatone amp the signal from the screen grid of one of the output tubes is fed back to the control grid of the other one, creating phase inversion. This technique was used in older radios in the interests of tube economy.
    MUSICTRONICS
    Electronics for the Music Industry
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    Oops.
    Thanks for the correction and explanations. I was looking for an 'input' elsewhere and had not seen this type of 'self-split' push-pull before. I saw the cathode but did not pay attention to the lack of bypass cap. It did not occur to me that it would serve as an input unbypassed like that.
    So why bother with PI circuits then? There must be some major drawback to this design?
    Cheshire, UK
    2,023
    Received: 326/4
    Given: 198/0
    15
    I think it's low output power.
    I wonder how well it would work as a low power option on a cathode biased amp?
    Use a double pole switch to ground one grid and disconnect the cathode bypass cap.
  1. First Rebuild- Electromuse Eye-Beam (for lap steel)
    By rjb in forum Beginner/ Hobbyist
    Last Post: 09-28-2011, 11:31 PM
  2. Replies: 4
    Last Post: 09-28-2011, 05:23 AM
  3. Electromuse A55 in dire need of repair
    By Resonator Guy in forum Vintage Amps
    Last Post: 04-12-2011, 04:36 PM
  4. electromuse A10 help please
    By tcac30 in forum Vintage Amps
    Last Post: 02-26-2010, 11:35 PM
  5. Fender bassman 10 - model number help
    By Mars Amp Repair in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-03-2007, 03:15 AM
