Results 1 to 4 of 4
Thread: Crest CA6 Power amp- in protection on one channel
    New Member
    Dec 2012
    1
    Hello Tech world
    I am new hear to this furum.This Crest amp came in with all the syptoms of a short in channel B. Channel A worked fine with PWR harness of B diabled. Now after bringing it up on the variac with channel A PWR diabled, it showed excesive current being drawn on B. So I decided to swap out channel A in place of B with maintaining A PWR harness disabled. It then showed a short with Channel A (the known good channel). thus leading me to think PWR supply problems with that side. Has anybody seen this problem any leads would be helpful. Thanks.
    Near Seattle, WA, USA
    663
    Most power supply problems will be present even without an output module installed, so check for proper rail voltages that way first.
    Could also be a problem on the preamp board, but that usually only happens after a major fault in an output module so comparison-check all the semiconductors between the working and suspect modules with a meter set to diode-check before doing a lot of module swapping.
    Problems on anything other than the output modules are kind of a PITA to run down on the CA series due to physical construction (as I'm sure you have noticed).
    Probably not the immediate problem - but look for any bulging or leaking main filter caps on the power supply board. Most of the CA amps I saw in recent years had caps that were starting to go. The smaller electrolytic caps on that board also tend to "dry-out" and go high-ESR.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,660
    Received: 588/1
    Start at the start, check the main rectifier bridge(s) and filter caps.
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    645
    Received: 4/0
    crest ca6, ca9, ca12, ca18 for reference
    I hope they help
    Attached Files Attached Files
  1. Power Transformers With Internal Thermal Protection Fuse
    By TomCarlos in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-18-2014, 01:51 PM
  2. EV 7200 power amp 1 channel not working
    By treatmint in forum Music Electronics
    Last Post: 06-30-2011, 12:43 AM
  3. Reverse Diode protection for Power Tubes?
    By leadfootdriver in forum Mods & Tweaks
    Last Post: 03-09-2011, 06:48 PM
  4. Bad Crest CA6 power supply
    By clintronics in forum Music Electronics
    Last Post: 09-04-2007, 05:54 PM
  5. Crest power amp
    By tonezoneonline in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-30-2006, 08:31 AM
